Panther6834
The MG90S should fit fine too, but you're limited to their included (and VERY brittle) ABS 21t horns, I haven't found any other horns that fit. Plenty of other options out there for dig servos.
It’s almost weak enough to be its own servo saver.
I've decided to give up on using the Hitec servo I'd originally intended on using for the DIG (though, I'll still be issuing the other Hitec servo, for steering). Here's why:
If you look at the Capra build manual, you'll notice that you don't attach a horn to the DIG servo. The Spektrum SX107 (the servo "recommended"...although, they should say "required...by Axial/Horizon Hobby) includes a small piece that attaches to the servo, instead of a horn (this piece, in-turn, operates the DIG through a second piece, which is actually a piece from a servo-saver).
What I've come to realize (thanks, in part, to Rich of RCN) is that the piece included with the SX107 fits a 23T servo spline. Since Hitec servos use a 24T spline, I can't use the Hitec servo. This is NOT to say you must use the SX107 servo. You should be able to use any micro servo you want, as long as it physically fits in the space provided...and, as long as it has a 23T spline (such as Sanwa/Airtronics, Multiplex, JR, MRC, or KO). But, at the same time, you'll still have to buy the Spektrum SX107, as that's the only way to get the servo-DIG piece.
Looks like I'll be contacting AMain for an RMA on the Hitec micro servo.
