Poprivet
No the pin is a tight fit once the outer coller on the side gears. No trouble drilling them but you can't do it by hand. Just mill a small flat, peck it with the center drill and then drill it with a 5/64" or #47 bit. I still need to find some permanent bearings to use, right now I just have some small traxxas bearings pressed in the stock ones. Forgot to measure the thickness so if anybody knows what it is I'd like to know.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thank you for that bit size.
The technique I get. I was just afraid drilling the hardened steel would smoke a drill bit. I will get 2 or 3 just in case.
