Very nice :mrgreen:
How do i get on the waiting list?
No list yet. I have to get through the first round of testing to make sure that it is a viable product. Once testing is complete, I will start a pre-order.
Is it going to be metal shafts or just the locker had to epoxy my rear shaft into the locker refuse to pay 28 dollars for one rear shaft that lasted all of about 5 mins
Initially, just the 2-piece locker, but I have a set of prototype rear shafts on the way as well. I was going to keep that quiet for a bit until it got through testing, but now that Chris_K is showing off shaft designs, I'll mention that I am looking into those as well.
My target price is $25, so I plan to undercut the Axial stock plastic price with my steel shafts.
Ok, so i ordered the AX31502
Universal Joint Axle Set 48mm (2pcs) from tower hobbies because it was cheaper than axial's price, and free shipping.
I hope it's the right part to replace my bent cvd shaft. There is no picture, and nothing on my bent stock shaft measures 48mm.
That looks right, according to the user manual (Page 19, as well as page 21 - exploded view.)
The 48mm is the measurement from the center of the pin that goes into the differential output cup, to the center of the pivot point of the CVD.
I don't have any pics of the spool but...
Started prototyping today.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Nice. are you planning on getting a vendor star so you can start selling these, or is this just a pet project for yourself?
What material are you using for the prototype? What about for the "final" version?
I was thinking of a vertical servo mount but rotate it up on end. That way the arm moves on the same plane as it would normally.
Let us know how that ESC works out.
A vertical servo mount should be easy to fabricate, and I like the idea of having the servo arm move in the same plane as the steering arm. Also, the way you are planning on mounting it is better than pointing the servo arm down. This would keep it clear of the chassis sides as the arm moves.
