Anyone ever use these ?
TacoCrawler
Anchorage, Alaska
https://www.ebay.com/itm/382504003230?var=651253404141
I'm trying to step the voltage down from a 4s Lipo which is fed directly to my light bar.
I have a quality 20A Castle BEC. But I'm saving that to run my 1/5 scale 12.6 volt servo.
My factory installed LEDs run @ whatever the voltage is, that the RX supplies.
This is solely for my lightbar which NHX says it needs 6v minimum to operate.
I have run this lightbar directly off a 3s Lipo with no real adverse effect.
So I plan on supplying 12v to this lightbar, to ensure its brightness.
The other LEDs feeding off the RX are not too bright and are more of a beauty LED light IMO.
Any ideas as to why this might not work ?
^ can they be water proofed ?
Was cheap enough to buy a spare.
I bought another just incase of an rainy day ! Lol
Look up conformal coating for electronics. It’s like nail polish, and works well. I’ve used nail polish too and it works. You could also use a rx box, I don’t think running the lights would put a big load on them for the heat displacement.
Hobbywing make a version of that too, not too expensive and it has a variable output.
It's a bit more expensive though, I think I got them for about $5 or something like that.
thanks for your participation :)
I'd wished I'd found that unit first. Because its voltage could be adjusted to the exact voltage wanted ? Sort of like my Castle Pro BEC ?
But is the adjustment made without using a pc link ?
Thanks for your participation :)
Nothing that fancy, it's a jumper switch that converts it from 5V to 6V - they do have one that goes higher than 6V but it's more expensive.
I only use them for LEDs really, so 5 or 6v is normally fine.
https://www.hobbywingdirect.com/col...-collections/products/ubec-3a-2-6s-lipo-input
They're $8 direct from HW, but you can probably find them lower price elsewhere.
