An $17 LCG transmission I stumbled upon.
Gula
Subscribed Member
Here
So i picked one of these up to see if it will help with body clearance on some of my builds.
Looks of good quality, all shafts are press fit or cross drilled and ride on bearings. The gears are a bit thicker looking than the old R2 trans. Looks super easily to be turned into a lightweight trans by cutting a bit off and substituting with a spacer. This ìs a picture i took off of ali, that someone had modified
I'm just curious of the gear ratio.
Re: An LCG transmission I stumbled upon.
Update, on the guts.
Has anyone else tried one of these? I want to put it into my tonka winnebago build and
Looks similar to the Dlux portal trans. I’m curious what the ratio is also
