magic_yeti
All started round christmas with a Tamiya Frog, but that's another story [emoji6]
After few weeks modding upgrading and testing, it was clear i can't get the Froggy run on my prefered ground.
So another RC Car the little Monster (Yeti Kit) was my decision to solve this Problem.
Fist stage of build:
Axial Yeti Kit
Castle Creation SCT Combo with 3800kv (5mm Version)
Axial 2-Speed Option
GPM Motor and Transmission Mount
The Arrival
As the Build proceeds i ordered the following Parts to complete it for the Maiden Drive.
Savöx 0231 for the 2-Speed, switches the gears like butter[emoji2]
Savöx 1210 SG for steering, would change it to HH SHV 500 now. but still pleased with the savöx.
Axial Rear Upper Link Plates, after my Tests a Vanquish Titianium Rear Upper Link would be the better decision
Castle Quick Link
GPM Heavy Dutys 14 mm front 22 mm rear, so no need for 12 mm nut, very happy with them so far.
Spare Methods, good idea mentioned for spare tire, but replaced the killed once.
After a few Days till the order arrived.
Froggy has a new Friend [emoji4]
Inspired on some treads i builded my first diy part a dust cover. cuted out of 0.5mm ABS.
Now it was ready for Maiden Drive. Using 2s Lipo borrowed from his Friend.
After first run checking the dust cover[emoji106]
All went well. But froggy burned the cheap turnigy esc, and as always planned to go 3s and not to risk the CC SCT Esc it goes into the Froggy and little Monster got an CC Monster X.[emoji2]
Changing to this Combo and 3s with 64/19 produces so much power. Now Parts starting to break during the test runs.
Killed the plastic methods
Bend the hinge Pin and the Alu Steering Ling
The hinge Pinis bending cause theres no help between the A-Arm. So i made a sleeve for between.
Using a 4mm and 5mm Alutube
Works great and caused the next breakage after a huge hit.
Replaced the frond links with traxxas, found this here on the forum. thx for sharing
Also the lockouts on the rear which i changed in the mean time to SSD Wide axle for AR60 gets loose.
I put in beeftubes, but thats only helps a little, so next diy modding. Add a screw in front and back, now its tide and i think this solves also axle bending. Switched to the SSD Wide Axle kit cause i bend the kit axle.
This was just to keep it running, SSD WIDE Diamond was on the way[emoji2]
Also after first run i see the stock screws getting rusty, so i ordered a kit of 12.8 torx from rc scrauben.
Out of the build process, what would i change in decisions:
start with better screws, install a beef tube or use SSD axle.
Next post i will write some of the painting process
hope i can give back some with this thread for what i get out of the forums here.
Gesendet von meinem T1-A21L mit Tapatalk
Axial Yeti Kit
The Arrival
Castle Quick Link
