Rockpiledriver
Extreme R/C XRC Comp Chassis
50/50 and 60/40.
The Extreme R/C XRC comp chassis package 3 comes with chassis plates, servo/link mounts, heavy duty 5/16" high clearance links, servo mount posts, body mounts and of course a slippery black delrin skid. This chassis has been very successful at the competition level. Ultra compact and light weight.
All for the low price of $109.95
http://www.rcpcrawlers.com/chassis.html
Castle Creaations Mamba Max Brushed and Brushless Speed Control
The hottest ESC available to the rock crawling market!
Infinitely adjustable throttle and brake curves
Punch Control to dial in the horsepower just where you want it
Brake Strength to keep you tracking straight under hard braking,
Drag Brake to help corner entries
Start Power for true and smooth launches
Cutoff voltage to keep your lipos happy
Timing Advance for that final tweak in performance
Cells 6-12 NiCad/NiMH
2-3s LiPo
Continuous 100 amps
Resistance 0.0003 ohms
Brake Proportional
Reversible Yes - with lockout
Low Voltage
Cut-off Programmable
Size ESC overall:
1.9 x 1.3 x 1.2"
Motor:
1.4" dia. x 1.7"
Weight
(w/wires) ESC:
2.5 oz (70.9 g)
Motor
7.0 oz (198.4g)
Connector Type Universal
Price $135.99
http://rcpcrawlers.com/esc.html
Holmes Hobbies RR2 Brushless Motor With Adapter Plate
This small motor weighs less than 1/3 the weight of a brushed 540 motor, yet has the punch to carry a 2.2 crawler through the toughest of terrain. Price Includes 540 adapter plate!!!
Only 2 ounces
Works on 6-9 cells nimh or 2-3 cell lipoly
3mm shaft
3.5mm plugs INSTALLED
915kv
25 amp continuous or greater brushless ESC required
Bolts up to standard 540 mount with included hardware and some modification, or with the optional machined adaptor plate.
A wrap of tape or aluminum foil is needed around the shaft to accept standard 1/8" pinions.
The shaft has no flat spot.
Price $48.99
http://www.rcpcrawlers.com/motors.html
Integy Hand Wound Late Motors
This is the hand wound version of the most popular motor in R/C rock crawling.
Available in 50, 55 and 60 turn configuration.
Features:
Hand wound armature
V10 motor can
Price $24.99
"thumbsup"
