A very intresting read I found about servo's and BEC.
crelesy
Zuid Holland NL/Dutch
I stubeled upon this when i was searching for some info on putting in a stronger servo on my LNC with stock elektronics.
I learned a lot from reading this..
Its quite long and based on rc hely's but still very useful I hope!
Digital Servos and BEC's
This is an extremely important post, and I urge everyone to read it. It is quite long, but it contains VITAL information concerning motors, speed controller and servos
We have been having an above average rate of failures of ESC's lately, and as a result, I have taken a great deal of time investigating this issue to discover the root cause. From what I have been reading in other posts in other threads and on other sites, this is not an isolated incident, and is affecting all brands of speed controllers. These failures are occuring about 98% of the time in helicopters as compared to airplanes, so obviously, there is something inherent to helicopters that is the cause.
The conclusion that I have come up with is that the true cause of the ESC failures is the servos that are being used in models these days. With the advent of the newer Digital Servos, and the current availablity of these servos are reasonable prices, just about everyone has switched to them.
a bit of education is necessary so here it is. I will attempt to keep it as simple as I can, but there are some electronics terms that have to be used, so try to follow along as best you can.
For those of you that do not know how a servo actually works, here is a crash course. A servo consists of a motor, a set of gears that reduce the speed and increase the torque of the motor output, a feedback potentiometer, a feedback amplifier circuit and a drive circuit.
A servo receives a pulse from the radio receiver that tells the servo what position it should move to. In a typical radio system, the pulse has a width that varies from 1.0 milliseconds at one extreme to 2.0 milliseconds at the other extreme, with 1.5 milliseconds considered to be the center point.
The feedback potentiometer in the servo provide a variable resistance that is converted to a varying pulse signal inside the feedback amplifier. The feedback amplifier then compares the width of this signal to the one that is coming in from the radio receiver. If the width of the two pulses are the same, then the servo sits still at that position.
If you move the control stick a bit, the width of the pulse coming from the radio receiver will change and the feedback amplifier will now sense a difference between the two signals. The feedback amplifier will then send out a signal to the servo's drive circuit, and this causes the motor to spin in the proper direction to match the new signal input. As the motor turns, it spins the gears in the servo. These gears eventually attach to the output arm of the servo and to the feedback potentiometer. As the output arm turns the potentiometer, the resistance value changes until a point is reached where it matches the position of the control stick and the servo stops at the new position.
This process repeats itself over and over again, hundreds of times per minute as we fly our models around, constantly matching the servo outposition to match the control inpuuts that we give at the transmitter. Now that we know how the system works, we can take a look at the difference between the older analog servos versus the newer digital servos.
In analog servos, the transistors used in the driver circuit were normaly traditional NPN and PNP bi-polar transistors. When these servos are set up in an amplifier circuit, there is a small range of operation on either side of neutral where the servos operate in a linear mode. What this means is that if you move your stick a tiny bit, the servo would react slowly at a lower power level. This would pull less current that normal, and the servo would move a little slower than normal. However, if you made a large stick movement, the servo would quickly ramp up to full power and full speed and move to the new position.
Since we are talking about current, I want to clarify a few things here about the different types of servo current. There are basically 3 different current levels you need to wory about. First is the Idle current. This is how much current the servo pulls when it is sitting still doing no work. In most cases, this value is very small, somewhere in the 5mA to 20mA range, which is very negligible.
The second current is the Working Current. This is how much current the servo pulls when it is in the process of moving from one position to another, with normal flight loads applied to the output arm. Depending on the size of the servo, and the applied load, this value can range from around 200mA up to 1 amp or more.
The last current is the Stall Current. This is how much current the servo draws if you hold the output arm from moving and apply a command to make the servo move. It is called Stall Current because the motor is stalled and cannot move. In this condition, the motor acts almost like a dead short, and pulls a lot of current. Again, depending on the size of the servo, and primarily the size and quality of the motor in the servo, this value can be anywhere from 500mA to 2 amps or more.
Another current value that has become very important is the Start Current of the servos. When a servo is sitting still at a fixed position, it only pulls the Idle Current. However, whenever a control signal is given, the motor has to go from a dead stop and accelerate to full speed. At the instant that the control signal is given, the motor is not spinning, so for a very brief period of time, the motor draws the stall current, and then as the motor starts turning, this current level drops down to the Working Current value of the motor.
With the earlier analog type servos, this start-up was softened somewhat because of the slight linear region of the transistors, so it never really got up to the short circuit current. However, with the newer Digital Servos, this is not the case.
The new digital servos use FET type transistors in the drive circuit, and these have almost no linear range around neutral. They also sent command signals to the motor much more quickly that the analog servos do, so the respond much more quickly. This change is what makes Digital Servos so popular with helicopter pilots. If you move the stick the smallest amount, the servo instantly reacts with full power to provide the desired control input. Helicopter pilots see this as a God-send, and use this power to perform amazing stunts with their helicopters.
The bad news is that this speed and responsiveness does not come without a very high cost. Unfortunately, very few pilots are aware of this, and it is this fact that has been the root cause of speed controller failures all over the world. ( I am sure you were al wondering when I was going to get back to the speed controllers. )
Because of the insanely fast response of the new Digital Servos, and the fact that they instantly go to full power every time you move the stick, they pull HUGE amounts of current every time they move. The new digital servos basically pull the full stall current of the servo every single time you make any control movement on the sticks. Due to the fact that almost all of the helicopters made today use CCPM mixing, there are 3 servos attached directly to the swashplate.
Any time you make a collective pitch change, all 3 servos move together in unison, starting and stopping at exactly the same time. This means that every single time you move the collective stick, you are hitting full stall current on all three cyclic servos for a brief period of time. As I have said earlier, these new digital often pull 2 amps of current or more in a stall, so when you multiply that by 3 servos, you are pulling current spikes that are 6 amps or more every time the colective stick is moved.
As you know, any time you make a collective change, the torque from the head changes, and the gyro compensates with a rudder input to the tail rotor. This servo will also react, adding to the current. When you start adding all of this up, you can quickly see how the BEC circuit is getting constantly hammered with HUGE current surges.
Most of the on-board BEC circuits are rated for around 3 amps with a 4 amp surge. For a 400 or 450 size machine with 325mm blades, this is usually sufficient, even with the smaller digital servos. However, when you start getting into larger machines such as the Logo 400, Trex 500, and others with 400mm or larger blades, the current levels from the servos can quickly out-strip the ability of the BEC circuit to provide the required current without over-heating.
When the BEC circuit gets overloaded, they either go into an over-current or over temperature protection mode and shut down for a while, or just burn out all together. If you lose the BEC voltage, the microprocessor in the ESC can no longer function, and whatever phase was turned on in the ESC when the power goes out usually stays stuck on. This pulls full short circuit from the battery, through the ESC ind into the motor. This current can be several hundred amps for a brief period of time, depending on the Rm value of the motor. Normally, the windings of the motor take several seconds to heat up and start to burn in this condition, but the FET transistors in the speed controller cannot handle that much current, so within about 2 seconds they start blowing out.
If you are lucky, the ESC burns open quickly and removes the load from the battery and motor and they survive the incident. In some cases though, the ESC welds shut from the current and takes out the motor and sometimes the battery as well.
The really sad thing is that the ESC itself is not at fault in this kind of failure. The complete fault for the incident lies in the current draw of the servos that exceeds the design specifications of the BEC. The worst part about it is that virtually none of the servo manufacturers out there give the full current specs for their servos, and some of them give absolutely no current specs at all. This places the blame for a huge number of speed controller failures squarely in the laps of the servo manufacturers.
part two (sorry its long)
What sucks about the whole situation is that the servos cause the problem, but they hardly ever see any damage as a result of it.
I went to several websites to pull the exact text from the specifications on several commonly used digital helicopter servos to see what they said. Here is what I found.
From the Futaba Website.
For the 9650 servo
SPECS: Dimensions: 1.4 x 0.6 x 1.1" (36 x 15 x 29mm)
Weight: .92oz (26g)
SPEED: 0.14 sec/60° @ 4.8V
0.11 sec/60° @ 6.0V
TORQUE: 50 oz-in (3.6 kg/cm) @ 4.8V
63 oz-in (4.5 kg/cm) @ 6.0V
How much current does it pull?
For the 9250 servo
SPECS: Speed: .11 sec/60° @ 4.8V
Torque: 76 oz-in (5.5 kg-cm) @ 4.8V
Weight: 1.9oz (54g)
Power Supply: 4.8V (Futaba does not recommend using 6V)
Length: 1.6 x 0.8 x 1.5" (41 x 20 x 38mm)
Current specs?
Ok, lets take a look over at the JR heli servos and see what they say.
From the www.jrradios.com website
DS9411 Digital Mid MG Servo
Specs
Size Category: Minis and Micros
Type: Digital
Torque: 82 oz/in @ 4.8V, 95 oz/in @ 6V
Speed: .15 sec/60° @ 4.8V, .12 sec/60° @ 6V
Dimensions (WxLxH): 0.71 x 1.41 x 1.03 in
Weight: 1.36 oz
Bushing Or Bearing: Bearing
Bearing: Dual
Motor Type: coreless
Gear Type: Metal
Gear Material: Metal
Um, How much current does this one draw? Idle current, Stall current, Working Current? Inquiring minds want to know.
Let's try another
DS8231 Digital Ultra Precision Servo
Specs
Size Category: Standard
Type: Digital
Torque: 88 oz/in @ 4.8V, 113 oz/in @ 6V
Speed: .22 sec/60 @ 4.8V, .19 sec/60° @ 6V
Dimensions (WxLxH): 0.75" x 1.54" x 1.36"
Weight: 1.73 oz
Bearing: Dual
Motor Type: Coreless
Gear Type: Nylon
Application: pricession pattern and jet airplanes, collective and rudder on helicopters
I looked further and found more information on this one.
Key Features
Outstanding holding torque that's 2-5 times greater than a conventional servo
Current draw is only 8% greater than a conventional servo
Ultra precise 5,900 step resolution for unmatched precision.
New wide-spaced output shaft dual ball bearings for minimal output shaft play
250MHz pulse rate for increased precision
OK, it pulls 8% more than a standard servo, How much is that?
Well it seems we have struck out with Futaba and JR, let's try Hitec and see what they say. Info from the www.hitecrcd.com site
HS-6975HB
Detailed Specifications
Bearing Type: Dual Ball Bearing
Speed: 0.13 / 0.10 sec @ 60 deg.
English Metric
Torque: 119.42 / 144.42 oz.in (4.8v/6v) 8.6 / 10.4 kg.cm
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 1.83oz 52.00g
Again, no current specs on the site. I did notice that they had a downloadable PDF available with complete servo specs, so I downloaded that and finally got a current specification.
On this sheet I got the following information:
Idle Current - 3mA when stopped
Running Current - 200mA at 4.8 volts, 240mA at 6.0 volts (No load applied)
Stall Current - 2400mA at 4.8 volts, 3000ma at 6.0 volts
Finally! A real current spec for a servo. My hats off to Hitec! My only recomendation to them would be to add this data to the basic specs found on the front page of the site. This is EXTREMELY important information, and needs to be put in the standard servo specs.
I would strongly urge Futaba and JR, as well as every other servo manufacturer out there, to follow Hitec's lead here and publish your current specs for the servos you manufacture. I would also urge every single modeler out there to contact the servo manufacturers and obtain a copy of the current specifications for the servos. If they are not available, we all need to pressure the servo manufacturers to test their products and provide this critical information to us.
As you can see, this completely confirms what I was saying earlier about the current draw of these newer digital servos. The Scorpion Switching BEC circuits in the 6-cell ESC's are rated for 3 amps with a 4 amp surge, and put out 5.7 volts. Based on the above numbers for the Hitec 6975HB servo, I would estimate that they would pull about 2800mA of stall current at 5.7 volts. If you have 3 of these servos together on the swashplate of a helicopter, the total stall current is 8.4 amps!! Are you starting to get scared now? I sure hope so, because this is what you are subjecting your BEC circuit to every time you move the collective stick.
Now granted, the 8.4 amp current surge is short lived, but when you consider the flying style of many of today's pilots and the maneuvers that they perform such as Tic-Tocks and hard shaking of the helicopter, the rapid pulsing of these currents really puts a beating on the BEC circuit. It probably will not fail right away, but I can guarantee that some time in the future, maybe 10 flights, 15 flights or 20 flights into the heli's life, suddenly, out of nowhere, the BEC will fail and your heli will be coming down.
When you get to the helicopter you find that the ESC is smoked and get on the phone, all upset, to the ESC manufacturer to ask for a warranty replacement. Well, I can safely say that the ESC is not at fault here, it is the excessively high current draw of the servos that are the root cause of the problem.
I would urge everyone who has taken the time to read this to copy this text and paste it on every other site or forum that you go to. This is a serious educational issue that needs to be spread around to every helicopter pilot in the world. This is one of the most important things that I have ever written, and I hope that everyone takes it to heart and makes the necessary modifications to their helicopters to provide the power needed to properly feed these very current hungry digital servos.
In the future, we will be closely looking at the ESC's that do come back, and if the BEC circuits are blown out in them due to pulling too much current, we will not be covering this under warranty. The 50% crash warranty will be in effect for this type of failure, because it is the end users responsibility to ensure that the parameters of the ESC are not exceeded. This includes both the ESC current AND the BEC current. If you are running a helicopter with 400mm blades or larger, and you have digital servos in it, you really need to get a seperate BEC system in there or you are going to lose your ESC eventually.
The purpose of this post is to shed some light on a very serious issue that is currently causing a huge amount problems for modelers out there. I hope that everyone out there takes this information to heart, and takes the necessary actions to ensure the life of their ESC and helicopter.
Sincerely,
Lucien Miller
Innov8tive Designs
In this text he mentioned that I could share this, so I did:roll:
So what, heli pilots are too good for an external bec?
1-They likely didn't know they needed one.
2-Weight, in flying machines, is a huge killer. Granted, a CC 10A BEC doesn't weigh much, but "A little here, a little there...." adds up. That is part of why they run CF bits, just to save weight.
So you know the max current needs, you know your ESC capabilities, what are your options?
1. bigger/heavier servo
2. CC BEC
I know they talk about helicopters in here, but I thougt I share.
In one big read they explane a lot about how BEC and servo amp's could cause trouble. And a lot about howe faillure's could occure on our rigs. Why you need and calculate your external BEC needs and stuff.
Expecially for the Newbie's in RC ( like me) it explaines a lot!
( sorry for my bad english, I am Dutch 8))
Great write up..
It made me check out alittle more specs on my 7980th...
http://www.hitecrcd.co.jp/RC/servo/pdf/hs7980.pdf
At 7.4v, which i run mine at, it can pull as much as 9A at stall :shock::shock:
And if i then go to Castle, and look at the specs of my "10A" BEC, it claims only 7A on 12v input (3s).. http://www.castlecreations.com/products/ccbec.html
So what should i do then.. Run my second option servo, a 7955tg, or lower the BEC voltage to 6v (7.3A stall current for the 7980 at 6v)..
Or just dont bother with it, and run till something burns up? :mrgreen:
Since most of us only run 1 high draw servo, and we don't pound it quite like the flying guys, I wouldn't worry about it.
The biggest thing for us is to make sure the steering EPA's are set correctly (stop the servo just before the mechanics bind up) and keep everything lubed & free (to reduce the load on the servo).
Then, a CC 10A BEC is fine."thumbsup""thumbsup"
Pretty interesting, makes sense.
so the short tale is basically because the ESC commands the servo more often than a plane, or ground RC that the internal BEC. shuts down and suffers the blow.
But as fas as I know from others in the hobby. And being one who lives in Montana where HeliProz. is located and one of the largest air RC groups in the nation. I would say 99% of these guys use an external BEC.
My big issue is for as long as I have been in Crawling, why no one except for Holmes Hobbies offers a larger BEC. In their ESC. Makes no sense at all for why others can't make crawler specific Electronics.
Personally, im sick of the 3S, low current BEC, ESC that keep you limited.
I run my Hitec 7954SH's straight off of 2s battery power without a BEC. How long until servo manufactures make some truly high voltage (i.e 3s and 4s capable) servos so we no longer require BEC's in any of our rigs?
Since I come from the manufacturing field, the answer to your question is, "It costs too much to do this tweak in existing products."
If a vendor was looking to do major changes (HH did a "from scratch ESC") then other changes/upgrades can be done. It all comes down to how much the change costs vs. expected sales returns.
Well, we tend to stall servo`s alot more often than 1/10 or 1/10 scale racer`s, thats for sure ;) (crazy binds etc)
But i`ll just let it be like it is for now..
Re: A very interesting read I found about servos and BEC.
OK...to be a PITA....what is "prolly"?????!!!!! I assume you mean "probably"??
I have kids, I want them to use correct English (even if it's American English.....):roll: [comment for my British friends....];-)
OK, in general, when you up the voltage, you drop the amps.
Good example, a room AC unit may pull 19 amps on 120VAC, change it to 220VAC it will draw ~9.95 amps.
Since the electric company usually bills on amps drawn, using a higher voltage unit is cheaper (once you get past the higher initial cost....).
I need some time time to do some tests on common crawler steering servos to see amp draw vs. voltage.
I'm curious if nobody else is.
Higher voltage for the same output the amps would be lower.
Same servo at 6V and 7.4V would give non linear current curves as efficiency differs at various volts.
For industrial equipment the threory holds true.
Say 200Kw motor at 550V and at 3000V draws less current at high volts for the same power but the volt loss per length of cable increases.
Thus super size cables for HV motors.
Something to look at in HV servos is possible thicker wires.
Say 20AWG wire for 7.4V and 22AWG for 6V.
A test set-up to see amps
OK, for now I will just use this thread as it has decent info & explanations (lots of hits in the search....).
I have a decent shunt, I believe it goes to 15A so the expected servo amp draws will get good resolution.
What I want to set-up is a test rig.
Good stable power supply (I'm using a modified server supply, 35A @ 12VDC, adjustable)
Shunt
Holding rig
Good servo arm with a mounting hole 1" from servo output center
Digital scale, one has a 30lb max weight (~480inoz)
-Test is to put the servo in a rig with the servo arm ~90* to the scale.
-Have a shaft go from the servo arm down to the scale.
-Hook up the PS, with the shunt inline with one power wire, and adjust to desired servo voltage.
-Connect calibrated Fluke DVM to the shunt (set to fast min/max).
-See the "static" draw off the servo.
-Full travel, rapidly, in each direction with no load, see the draw. (added 7/4/2012)
-Command the servo to drive the arm & shaft towards the scale, see the amp draw.
-Command the servo towards the scale and hold it there, see the "stall torque amps".
I'm curious to see what the results are.8)
Is anyone else interested?
If so, should I add it here or start a new thread?
Does anyone see issues with my test set-up?
I'm around this week, on the road the next couple, so testing is when I can.;-)
Re: A test set-up to see amps
I'm very interested to see your results.
The only thing I can think to add is just a suggestion on measuring voltage. I would suggest that you monitor the voltage on the wires that go to the servo's plug in case there is any voltage drop on the connection - probably unlikely, but was just a thought I had.
