ElChupacabra
I recently upgraded to a 4PLS. I've been using the stock RX that comes with it in my 1.9 rig and it's been great. I ordered 2 of the Futaba R2106GF RX to stick in my Wraith and my Slash. After trying to install the new RX in both trucks I'm having a throttle problem. Both RX will bind. Both RX power on and the ESC fire up normally. (tried it with 2 different AE-2 and a MM). I get no throttle response from either RX hooked to either ESC. The lights on the ESCs all look like the throttle input is being received, green for forward, switches to red when thrown in reverse. I've tested all 3 ESCs I've been using with the other Futaba RX and they all work fine. I also tested all 3 with the crappy stock axial RX/TX combo and they all worked fine. I've checked all the settings on the TX, I've searched all over the internet, and I've read the manual section on throttle several times. Nothing I've tried seems to work. I can't get the actual motors to spin, and yes, I tried all 3 ESC combos with other motors and everything is working. It's 100% something to do with the TX I'm guessing and some dumb setting more than likely. The only thing on the internet I could find was a thread describing the same issue but the OP magically solved the issue and never posted how. Any help or direction appreciated...
I'll add that the servos and steering function perfectly in every setup while the throttle is having this issue. It's clear the RX is getting input from the TX and relaying it.
