8300Angstroms
Focused 2 brands:
For those who have used either,
CoG: Did these help lower it? Seems like it should, being these are machined Al & stock portals are plastic. In theory, they most lower the CoG, but is it significant?
4WS: Has anyone purchased to 2 sets of steering (i.e. front) portal axles, to enable either 4 wheel steering? Dependent or independent.
Simple way would be dependent steering, using 2 steering servos; one per portal axle. Then setup the transmitter to either keep the back wheels straight, or rotate in opposite directions. (e.g. If the front steering servo rotates 15 degrees clockwise, rotate the rear one 15 degrees counterclockwise.)
Wiring issues aside, how difficult was it to mount a 2nd steering servo?
- Super Shafty --> https://supershafty.com/collections...hafty-cp44-axle-system?variant=31181181255774
- Vanquish --> https://www.vanquishproducts.com/axial-capra-currie-f9-front-axle-clear-anodized/
