I wasn't super thrilled about the lip created by the cross member so I set out to fix that.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160724_213818_zpsmlj6jsen.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160724_213818_zpsmlj6jsen.jpg" border="0" alt=" photo 20160724_213818_zpsmlj6jsen.jpg"/></a>
Some stuff that came up first.
I was thinking a drainage system out the back using RC4WD sand ladders as grates in the floor. Good for tying things down too.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160726_093843_zpshy7717ug.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160726_093843_zpshy7717ug.jpg" border="0" alt=" photo 20160726_093843_zpshy7717ug.jpg"/></a>
I have a hard time letting things go...
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160724_224511_zps7ampygjs.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160724_224511_zps7ampygjs.jpg" border="0" alt=" photo 20160724_224511_zps7ampygjs.jpg"/></a>
Not diggin' either one I decided to move on. I was thinking of adding more support and just bringing the floor flush with a simple platform using left over scrap from the cross member.
Started messing around and discovered this. Which triggered the drawer idea.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160726_224648_zps89jekdpg.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160726_224648_zps89jekdpg.jpg" border="0" alt=" photo 20160726_224648_zps89jekdpg.jpg"/></a>
After thinking about it for a good long bit, I started to put together a frame.
The idea was to build a smaller frame out of the large tubing and and add a bottom to it. Then attach two smaller tubes off one end of the frame. Next, insert the smalls into the larger tubes (dotted lines) allowing the drawer to slide out via some fancy piston action.
<a href="http://s1376.photobucket.com/user/thekraigen/media/Screenshot_2016-07-29-11-31-02_zpsoiuamy4u.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/Screenshot_2016-07-29-11-31-02_zpsoiuamy4u.jpg" border="0" alt=" photo Screenshot_2016-07-29-11-31-02_zpsoiuamy4u.jpg"/></a>
Framing done.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160726_232025_zps4tf94e69.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160726_232025_zps4tf94e69.jpg" border="0" alt=" photo 20160726_232025_zps4tf94e69.jpg"/></a>
Inserted the drawer bottom and got it all in place.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_080112_zpsqfg47ewf.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_080112_zpsqfg47ewf.jpg" border="0" alt=" photo 20160727_080112_zpsqfg47ewf.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_080123_zps56w1iyzf.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_080123_zps56w1iyzf.jpg" border="0" alt=" photo 20160727_080123_zps56w1iyzf.jpg"/></a>
Made a floor to put over top.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_080148_zpssazfgc9s.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_080148_zpssazfgc9s.jpg" border="0" alt=" photo 20160727_080148_zpssazfgc9s.jpg"/></a>
After sanding down the smaller tubes they slide very nicely.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_080207_zpswt1koefh.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_080207_zpswt1koefh.jpg" border="0" alt=" photo 20160727_080207_zpswt1koefh.jpg"/></a>
It did dawn on me at this point the drawer would need some sort of handle ;-) Which wouldn't fit with this current layout. So I removed roughly 5mm off the pistons. Doing so revealed a step up into the cargo area that I really like the looks of. Also provided the extra room for a handle of some kind.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_113101_zps4mrzp7ul.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_113101_zps4mrzp7ul.jpg" border="0" alt=" photo 20160727_113101_zps4mrzp7ul.jpg"/></a>
The way the drawer is set up there is a big cavity toward the front. Thought I should utilize the space some how.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_113259_zps3hi5q7gu.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_113259_zps3hi5q7gu.jpg" border="0" alt=" photo 20160727_113259_zps3hi5q7gu.jpg"/></a>
Access to concealed storage from both ends "thumbsup"
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160727_112907_zpszyqwktnp.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160727_112907_zpszyqwktnp.jpg" border="0" alt=" photo 20160727_112907_zpszyqwktnp.jpg"/></a>
A hinge was needed now but it had a few requirements. First it had to be hidden. Second, it needed a tight fit. Lastly, it had to allow clearance. Being boxed in so tight (not wanting a gap in floor) it had to come strait up then could rotate open. Ended up trixier than I first imagined.
I stumble on Mr. DetroitMuscle 59 on YouTube and learned how to make these puppies. Thanks Man!
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160726_084601_zpscs00ygxr.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160726_084601_zpscs00ygxr.jpg" border="0" alt=" photo 20160726_084601_zpscs00ygxr.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160726_084236_zpsg9vtr1kh.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160726_084236_zpsg9vtr1kh.jpg" border="0" alt=" photo 20160726_084236_zpsg9vtr1kh.jpg"/></a>
Trying out this guy. Works ok. You can see the recessing for the handles as well.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_215252_zps0rqxc1bo.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_215252_zps0rqxc1bo.jpg" border="0" alt=" photo 20160728_215252_zps0rqxc1bo.jpg"/></a>
Peeekaboo...
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_220115_zpsjtbg8plu.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_220115_zpsjtbg8plu.jpg" border="0" alt=" photo 20160728_220115_zpsjtbg8plu.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_215431_zpsrvqfkxkm.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_215431_zpsrvqfkxkm.jpg" border="0" alt=" photo 20160728_215431_zpsrvqfkxkm.jpg"/></a>
I'd say its decently snug. You can see a recessed handle idea for the cubby. Not sold on it yet.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_210857_zpsquv3cenm.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_210857_zpsquv3cenm.jpg" border="0" alt=" photo 20160728_210857_zpsquv3cenm.jpg"/></a>
Handle for the drawer...
Same design as the one for the cubby but I like it used here much more.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_220241_zpsy88damwx.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_220241_zpsy88damwx.jpg" border="0" alt=" photo 20160728_220241_zpsy88damwx.jpg"/></a>
At this point nothing but the drop bed is set in stone yet but i like it. Also considering the entire interior
Guess we'll see how this turns out first.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_110017_zpsy4xkqanp.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_110017_zpsy4xkqanp.jpg" border="0" alt=" photo 20160729_110017_zpsy4xkqanp.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_110102_zpsfecmob4l.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_110102_zpsfecmob4l.jpg" border="0" alt=" photo 20160729_110102_zpsfecmob4l.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160728_210235_zpsjj96aezv.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160728_210235_zpsjj96aezv.jpg" border="0" alt=" photo 20160728_210235_zpsjj96aezv.jpg"/></a>
While I think about colors and materials to finish it all I get to start on seating possibly or maybe something else.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_141905_zpssdm7csjt.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_141905_zpssdm7csjt.jpg" border="0" alt=" photo 20160729_141905_zpssdm7csjt.jpg"/></a>
Lots of room for different possibilities.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_141839_zpsuv1iw4ee.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_141839_zpsuv1iw4ee.jpg" border="0" alt=" photo 20160729_141839_zpsuv1iw4ee.jpg"/></a>
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_141819_zpspr0p8m5m.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_141819_zpspr0p8m5m.jpg" border="0" alt=" photo 20160729_141819_zpspr0p8m5m.jpg"/></a>
Would like to simulate this somehow.
<a href="http://s1376.photobucket.com/user/thekraigen/media/Defender%20Floor%20Mat_zpspsfpt03f.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/Defender%20Floor%20Mat_zpspsfpt03f.jpg" border="0" alt=" photo Defender Floor Mat_zpspsfpt03f.jpg"/></a>
UPS came by for a visit while writing this. Lots of work is what he brought.
<a href="http://s1376.photobucket.com/user/thekraigen/media/20160729_130709_zpsapvuevlf.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20160729_130709_zpsapvuevlf.jpg" border="0" alt=" photo 20160729_130709_zpsapvuevlf.jpg"/></a>
Any tips, critiques, suggestions would be greatly appreciated. Still very much stumbling through this one piece at a time. My experience with gluing painted bits did not go so well. I'm unsure how to go about applying color to it before adding the final materials.
