The bumper is mounted. I opted for maximum protection. The ARB Land Rover winch bumper from RC4WD (Part# Z-S0853) looks like it should deliver. With winter coming, it may be a while before it gets tested. Even though mine sits just a hair off, it really is a nice bumper. If the look does it for you the build should definitely satisfy. Mounting strait to the chassis and not to the stock bumper resulted in the body making contact with the bumper ever so slightly. I'm comfortable with it but any closer and I wouldn't be.
Turns out I actually have the plastic tree that the bumper uses.
[IMG<a href="http://s1376.photobucket.com/user/thekraigen/media/20151118_163124_zpsjmp4xjxc.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20151118_163124_zpsjmp4xjxc.jpg" border="0" alt=" photo 20151118_163124_zpsjmp4xjxc.jpg"/></a>[/IMG]
Also picked up the RC4WD 1/10 Warn 9.5cti winch (Part# Z-S1079). Had to turn the silver plate that comes attached to the winch 180 degrees in order to get it to fit down in the bumper. Still need to pick up a receiver for it. Looks the part we'll see how well it pulls 10lbs of stuck truck.
[IMG<a href="http://s1376.photobucket.com/user/thekraigen/media/20151117_195449_zpsc6qatwcx.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20151117_195449_zpsc6qatwcx.jpg" border="0" alt=" photo 20151117_195449_zpsc6qatwcx.jpg"/></a>[/IMG]
The Gelande 2 Steering Guard (Part#Z-S0824). Wasn't sure how well it would bolt up with everything else being added to the front. Those tires are RC4WD 1.9 Flashpoints on the stock rims.
You can see I moved the steering guard back one hole from where it should be. The reason is it hits the brace that connects the bumper to the frame. If you do mount the ARB bumper to the stock bumper I believe you would be able to bolt everything up to spec. As it is, it just barely works with a bit or contact to the pan hard upper rod end. If the shocks get changed out, this will have to be rethought out.
[IMG<a href="http://s1376.photobucket.com/user/thekraigen/media/20151117_195226_zpsjtwkntdn.jpg.html" target="_blank"><img src="http://i1376.photobucket.com/albums/ah16/thekraigen/20151117_195226_zpsjtwkntdn.jpg" border="0" alt=" photo 20151117_195226_zpsjtwkntdn.jpg"/></a>[/IMG]
and the Inner fender set for the D90 body (Part# Z-S1194). Please excuse the ever growing nest of wires. These were very strait forward. Cut, drill preset wholes, sand edges, paint, then finally bolt up. They are made of a flimsy lexan like plastic that at first touch, I regretted buying, but once bolted up prove to be a lot more rigid and I think they will work very well.
You can see the temporary electronics here. I haven't decided on a motor and ESC yet but leaning towards the Tekin FXR and their 45t Pro crawlers motor. I only have experience with a Novak 2s Goat Brushless System which I have grown to really like a lot over the years but have been wanting a brushed setup for a while. What do you all recommend? The rig is Heavy and precision is everything to me. Should I go with a bit more modern censored brushless system instead?
