Rock Crawlers in my state all gave up and only play on that useless bookface, so i haven't done any kind of comp or trail run in years. But the Truck and Construction guys actually want to play and do meets!
I wanna roll with the gangstas, but don't have the $$$$ to go hydraulic anything, and tamiya semi kits usually stack up money faster than a rock crawler. So, we're going Old School... Cable Machines.
In 2016 I started into this other aspect of RC with some rusty old pressed steel. Originally I really wanted a ''Unit Crane'' as i had already seen some sweet looking builds on that chassis, but at a Used Stuff store i found a 1965 Structo dump truck and a 1955 nylint Michigan Crane T-24. Cheap and rough enough i don't think the collectors will want to fight me for "Ruining'' them by adding too much awesome.
Ok i was excited and i already made a boom extension, and a dragline bucket before i started breaking it
http://www.rccrawler.com/forum/gene...-structo-dumptruck-redcat-everest-1-16-a.html Dumps like a Truck truck truck
The real build threads for these were on Scale4x4rc and Rctruckandconstruction, but one completely went away, and the other is down right now, so this is more of an overview than full build. Plus it's on 2nd image host so some stuff will be out of sequence.
Mostly this is based around some Hitec hs645mg servos modded to continious rotation. Flysky fs-i6, a BEC, couple versions of blinky lights, and the Operator you'll meet later. I copied pretty heavy on a build by "rvjimd" who had some videos, and an overview thread.
Drill some spot welds, the engine housing lid comes off, then remove a push-nut.
Prep the chassis with a bushing and an Align Trex 500 main gear. Some math required.
Then prep the crane House with a slew servo, same pitch gear is splined to servo, the aluminum servo mount dropper plate is slotted to adjust gearmesh
A cool dude made some aluminum parts for me
3 cable drums
2 hoist pulleys
2 boom lift tip pulleys
2 boom lift house pulleys
1 crowd pulley (we also get a crowd roller later)
1 servo mounting L bracket
Sometimes a plan comes together
This is already many months in, so this looks like a good spot to take a break
3 cable drums
2 hoist pulleys
