Started work on a garage radio.
It's a 1938 General Electric G-76.
How it looked when I spotted it. $80 later I took it home.
Brought it into the garage and it instantly looked better.
The finish looked decent but since it had scratches, water stains, and some peeling veneer, I wanted to re-finish it and update the electronics. Sort of a resto-mod.
I gutted the cabinet and masked the opening before breaking out the oscillating saw. (This picture was actually taken just prior to removing the panel, but you get the idea)
Panel removed
I have two sets of speakers to mess with, some Bose 201s from '91 and some Klipsch stuff from 2000 or so. The Klipsch stuff sounds great but the woofers need new surrounds so I removed them from the enclosure and got to work.
The woofers are 6 1/2" 6 Ohm units and they sounded great before the surrounds took a dump so I decided to re-build them and put them to use.
A razor knife with snap-off blade was used to cut under the trim ring and remove it from the basket.
The oscillating saw with a flexible scraper made short work of removing the old surround from the basket.
One down, one to go.
The Klipsch horn (tweeter) has a double-stacked magnet.
The Klipsch 3" mids are in good condition. They don't need new surrounds like the woofers.
So it's a start. Open to ideas. Everything I work on is usually in flux and finds itself as I work. :lol:
Panel removed
