  • RCSC
12v direct power servo for steering 1/8 scale
Vancouver
I am considering an AGFRC 12v 45kg servo (SA75CVSW) for my 1/8 scale basher. I'm using it in dirt, snow and sand... So strong steering is important.
Is it worth going to direct power? Will it end up being a noticeable reduction in play time?
AGFRC has a 45kg servo (A81BHMW) that is not direct power and provides similar speed and a bit lower strength @ 7.4v.
My ESC is a 150Firma.
Will there be much of an effect on overall run-time?
im my opinion you would get more run time less stress and heat in the esc trying to modulate the voltage for a servo and because of the higher voltage you use less amps so the entire servo system becomes more efficent
and if that servo is brushless you will save even more power
ive never acctualy tested the theory though i rearly run my batterys down enuff to make a differance for me all i really notice is i have better steering with no glitching
