nedmo
Hey bud awesome build. Very close to a build I have on the bench. What wheelbase did you go with?
Another stunner DPD! I love all the detail. She looks like a worker.
Selling it already?
Hey thanks WB is approx. 12 1/4
Yeah cool, Im aiming for about that as well.
What is the length and width of your cage work at its longest/widest points? Really hard to judge scale!
Awesome buggy. I'm just about to finish up my moon buggy and it's cool to see some other scale moon buggies out there.
Great build, really nice colour scheme as well"thumbsup"
What do you use for tubing for the chassis/cage?
Rear panhard for Currie F9
Your fine I like newbs! "thumbsup"
You are correct triangulation isn't needed with panhard setups. Panhard does most of the work there. (Infact panhard 3 links work better if upper and lower links run straight back from the chassis to axle mounting points)
But because this is a center diff axle (and I was too lazy to add in a proper upper axle mount for the 3 link) it just gets mounted outside stock mounts for now until I incorporate a upper link mount near the panhard mount on the axle.
Triangulated 3 link panhard setups work ok, but work much better as stated above. Hope that makes sense....:mrgreen:
The rear portal setup I had on this was a proper set up for this application with offset diff and parallel links "thumbsup"
