TheSubaruJunkie
FJ Cruiser build using WPL C24 chassis
So I was surfing on eBay for some used WPL parts, and saw this body listed. The body is from some kids toy, and the previous owner had cut the motor and axles out so I sent an offer and ended up getting the thing for around $20 shipped. I am not very satisfied with the condition the body is in, but I know I will have to cut it up even more and with some fresh paint it wont look anything like this when im finished.
Here's a picture of the body next to my sons C24 for scale.
They aren't a perfect match, but they will still look good on the trails together. As you can see here, the wheel base matches perfectly to the WPL C24 chassis.
Here it is with the donor truck, ready for the chassis transplant.
It didn't take long to mark where to cut, and then take the dremel to it. I ended up removing quite a bit of plastic, afterwards it was just a matter of setting the right ride height, and then strategically applying large gobs of hot glue to hold the base of the body to the frame.
I am not concerned with the mess, because all of this will be covered by the body. And from underneath it doesn't look half bad at all (if you ask me)
The chassis sits perfectly level with the underbelly and I cut the springs so the suspension sits lower but offers more droop.
Here it is all mounted, next to my C14.
And I had to steal the wheels from my sons C24 so I could see how it looks.
Looks good but I might have to find something different so I can add a bit of variety. The next step is to paint the body but Im not real sure what color to go with. Kind of leaning towards yellow....
