All axle width info...
Bugs Crawler
Greensboro
So while looking for some info for a upcoming build I thought to myself "wouldn't it be nice to have all the axle width info for all the vehicles associated with RC crawling, scalers, Ultra4, bouncers, ETC??"
I know this was tried before back in like 2008 but I feel that with all the newer trucks this seriously needs an update. And YES, I know how the search button works. But with that said I hate the search function on RCC, I feel I get too many Random results most of the time.
So Ill start with the ones that I know of so far as well as list some I feel should be added to the list. Ill update the main post as more info is posted. Also if someone could pin this as a "sticky" that would be cool.
Feel free to add any vehicles I missed in my suggestions or if I am wrong about something.
_______________________________________________
This will be for axle widths measured hex to hex in inches..
Axial SCX10/AX10: 7.625"
Axial SCX10II: 7.375"
Axial Narrow XR mod: 7.875"
Axial Wide XR mod: 8.75"
Axial Yeti/Exo Terra front: 10.125"
Axial Wraith/Bomber: 9.5625"
Axial Capra: 8.73"
Axial SCX10.3: 7.4375"
Losi Night Crawler: 7.5625"
Traxxas TRX4: 7.875"
Gmade Gom: 10.125"
Vaterra Slick Rock: 5.65"
Team Associated CR12: 6.1"
MST CFX: 7.6"
Boom Racing BRX70 phat axle: 5.846" ( pin to pin )
Here are some current suggestions of more widths to add:
Axial Ryft
Rc4wd Trailfinder 2
Losi Rock Rey
Losi Lasernut U4
Losi Tenacity DB (sometimes used for U4)
Vaterra Twin Hammers
Vaterra Ascender
Vaterra Slick Rock
Gmade R1
Gmade Komodo
Gmade Bom
Gmade Sawback
HPI Venture
Redcat Everest 2.2
Redcat gen7 and 8
Redcat Camo X4
Redcat Wendingo
Cross RC demon
Element Enduro straight axles are the exact same width as the AR44s
Just for the Axial portion I think it would be simpler to list by axle designation since they use them on several rigs (AR44,AR45, AR60 etc)
Just opinion here, but I think a list of axle widths would be better if it had aftermarket widths since most guys wanting to modify one of the trucks on this list already own it (brand to brand swaps are kind of rare, never see someone wanting Gen8 portals on a 10iii), or are looking for a one-off setup, or are using a tried/true axle like an AR44. I would be more interested in seeing the width of say a Pro44 compared to a Boom Racing PHAT or Vanquish Rock Jocks/V2s or the like if I was building a one-off rig.
SCx10-iii AR60's 7.4375 (7 7/16)
I don't have calipers wide enough so had to use a tape measure so might not be 100% accurate
Losi MRC Pro (& V. Slickrock?) - 144mm, 5.65"
MST CFX-W - 193mm, 7.6"
AE CR-12, Thunder Tiger Kaiser XS - 155mm, 6.1"
I do like the idea of listing aftermarket axles as well. My thoughts for whole list/stock rigs would be in the case that someone was considering buying or using a certain rig for a certain purpose and needed to stay within a width to fit a certain body, class, etc. I know certain ultra 4 classes have strict width measurements. As well as if you were wanting to build a class0 or class1 truck and wanting the narrowest axle setup possible. Or if someone was considering doing a wide XR mod and didn’t want to buy the parts without being able to compare first. Things of that nature.
Thanks guys, Keep them coming. I have updated the list thus far. Ill possibly go back later on and put everything in alphabetical order.
This is from the other thread. Yours is called 'all axle width' and that one is called "width of all axles" haha. Is a sticky in one of the other forums. But definitely needed updating with the newer rigs.
TLT: 7 1/4''
TXT: 9 3/4"
High Lift:
Clod: 9 3/4''
AX-10: 7 9/16"
Wheely King: 8 5/8''
PTI:
E-Maxx: flat 14 7/8"
X-Factor: 14''
Twin Force: Stock-12''/2 Long-13''/2 Short-10 1/2"
Axial's are only 7 9/16" face of hex's.
WK's are in fact 8 5/8" face of hex's.
Maxx's I have (not sure if they are wide Maxx or not): 14 7/8" (w/3.3 knuckles)
Revo's (just for the heck of it ): 14 5/8"
Losi mini: 5 1/2" (stock)
Bully Widths:
2.2: 7.6"/193mm
XLD: 10.4"/264mm
Super: 11.4"/290mm
Losi Comp Crawler/Night Crawler:
7 9/16" outside of hex, both front and rear.
wraiths are 9.57" long, hex to hex
Gmade R1's are:
8.75" Hex face to hex face.
RC4WD:
Cast yota axles 6.95"
K44 axles 6.929"
T-rex 60 7.24"
D35 6.96"
Blackwell standard width 7.55"
That's funny that someone was asking on that thread right after I started this one. That was the thread that I was referring to in my original post. Ill start updating this one again with some of that information as well. My goal is to have all the info laid out in one post in possible alphabetical order for Make/Model. I appreciate all the info everyone has posted up so far.
Might be able to create a 3rd one, call it something like "Axle Width Master List", and have Admin delete the other 2. They are both a little messy but that's what happens with things like this.
All are taken face to face from each hex. (+/-2mm)
Venture axle195mm
Hpi Super nitro rally ifs 195mm
Hpi MT2 front ifs setup 245mm
Wendigo axle 238mm
Cc01 rear axle 157mm
Can someone add some of the Element axle widths?
Specifically the Gatekeeper :lmao: , inquiring minds want to know :ror:
All the Element 1/10th rigs use the same solid axle.
Enduro Sendero, Trailrunner, Knightrunner, Gatekeeper, Ecto, and the old discontinued Trailwalker..."thumbsup"
Howdy all,
Does anyone know if the Vanquish Capra F9 axles are the same track width as the Axial Capra axle? I can't seem to find that specific info. I'm guessing that it is, but I just want to double check.
Thanks!
s
