Had an eye on this kit for a very long time. Finally a letter to Santa and it came true
For the Defender body, the 8057 short to long chassis conversion kit is needed (that I knew of) AND 8215 body posts (missed that one...)
Never build a Traxxas kit, some things are different, but I like them:
All in all, surpisingly pleasant build experience.
A few build notes:
After chassis assembly I was left with two 3x10 screws, but can't figure out if they are extras or I missed something. Besides parts not used because of the conversion kit, these are literally the only extra parts left.
Question: according to manual, plastic to plastic and plastic to metal rotating parts are not greased (gearbox fork; pinion to spur). Is it wrong to grease them?
- I really like that each major stage has it's own bag and there are (almost) no extra parts making you wonder if you missed something
- Don't really complain of links and shocks coming preassembled
- Also no complains of parts coming already detached from part trees
- Radio pre-programmed; since it does not have a display and the bluetooth module is not included, this is a real plus
A few build notes:
- That's a lot of screws
- When tightening slipper, watch for spur wobble - easier to fix it at this stage
- Front portal input gears tend to rotate inside their bearings - a little grease fixes that
- Servos are labelled - I did not notice
- Wire routing for diff lock servos is a bit tricky since they have a "bulge" on the cable and there is little space between them and chassis. Beware of pinching the cables
- Due to extension kit, you'll need the two 3x12 screws that are normally used on battery tray on rear shock towers - no issue, you'll be left with two 3x10 to use on fixing the tray
- Extension kit instructions are a bit small, pay attention to rear shock towers orientation
- Really, that's a lot of screws, my right hand is filing a complaint as we speak
