Very sorry Gazzalene unloaded on you. ��
Thx cheez "thumbsup", but not a big deal. We tried it, but if he takes it like this. Not my prob. I know my little monster and i can read ;-) ..
We have a saying in german: Was kratzt es die deutsche Eiche, wenn die Sau sich dran reibt.
What does it itch the German oak tree when the sow rubs against it. (Hope translation is not too bad)
Small update regarding the rear axle inspection,
- Rear axles still straight, no bending. But the pin hole shows some wear, they will go in the parts box 8) as quick replacement and replaced by new ones i already have. Ordered replacements as i ordered the axle, to have quick replacement:mrgreen:. Remembering the posts about axles bend, i think it was a good decision to use pin mounted hubs:mrgreen: in combination with the wide axle, they have minimal to no slope between hub and axle and i don't need lockouts8).
- the torque master locker i use has some slope on one side - will replace it
- Rear gears have little wear, will exchange them with the ones of little Frankenstein
- striped 2 screws next todo :mrgreen:
Not much progress right now. A Capra came in the way
Running out on middle splines. Considering to switch to SSD Rear Drive shaft. Any experience with this option? So i don't loose a spline, if the rods of the trailing arm break, cause it's 2 piece design. Or buy a new plastic set to get splines, cause i like the wild bores with the shiny peaces:mrgreen: and no issues beside this. Maybe secure the spline somehow.:???: we'll see
