dezfan
Sup peeps, I’ve been using the same Lipo Charger for years. It’s an old IMAX B6 4 button style 80 watt charger.
I use a 12v 5ah AGM battery as my power supply. I added a digital volt meter to it to keep an eye on the battery’s voltage and I use a CenTech trickle charger on the battery when charging.
<a href="https://ibb.co/2F8mtN0"><img src="https://i.ibb.co/kG3k81V/08-F777-B3-4-AEB-4420-955-D-78-EDB0108-D73.jpg" alt="08-F777-B3-4-AEB-4420-955-D-78-EDB0108-D73" border="0"></a>
<a href="https://ibb.co/6wMfzkB"><img src="https://i.ibb.co/c3B70jL/49-E684-D4-5871-4-DA6-B173-1-F0-E2-D1151-CD.jpg" alt="49-E684-D4-5871-4-DA6-B173-1-F0-E2-D1151-CD" border="0"></a>
It works fine, it’s just slow.
Been thinking about getting a new charger. Something more modern.
The charger I’m looking at is the Junsi I-Charger x6 rated at 800w.
<a href="https://ibb.co/1RkhkvY"><img src="https://i.ibb.co/RQqZqvG/60-FB01-A2-3-B48-44-B8-ADFE-D0-EE284-FE230.png" alt="60-FB01-A2-3-B48-44-B8-ADFE-D0-EE284-FE230" border="0"></a>
Anyone use one or one that is similar?
What I’m wondering for anyone who may have used this charger or a similar one, would my 12v battery be sufficient to power it, or do I need to invest in a power supply as well?
It states that the Input Voltage Range is 10.0—32.0VDC. My little AGM battery on the trickle charger averages 13-15 volts.
If I could get away with not buying a power supply for a while and just getting the charger, that would be preferable.
Any input would be greatly appreciated, thanks.
