Micro wheel spacers?
BIGW0RM
Orange County, CA
Does anyone know where I can get some 7mm (micro hex) wheel wideners? Id like to push the wheels out on a micro I have and can not find anything to do so.
Ive googled 7mm wheel hex widener, spacer, hub, adapter, and I can't find anything but custom offset shapeways wheels which Id rather not use.
If anyone has a source please let me know.
Thank you,
BW
Somebody used to sell them on eBay, but I don't see them anymore.
Mil Stone brass wideners.
Keep in mind the Trekker already has wideners so extending past the knuckle gives a horrible scrub radius causing the entire wheel to shift when it turns.
He's out of stock at the moment, but the seller is https://ebay.com/usr/kinetic-kms
Sent from my LGMP450 using Tapatalk
Thank you very much. I will monitor his page for those. Thank you!
Heres a set from Amazon. I ordered these for my RGT Adventurer to fit some RC4WD wheels. I never actually installed them because I lost a BUNCH of the screws trying to put the stupid wheels together and ultimately got frustrated and gave up, although I'll probably revisit it this summer.
https://www.amazon.com/Hobbypark-Al...=7mm+hex+hub&qid=1553529841&s=gateway&sr=8-30
Those are standard 7mm wheel hexes and are only 3.5mm thick. I'm not sure what stock hexes are, but without a barrel nut I wouldn't expect to get the wheel past the threads of the axle shaft.
