Inspector86
I have 5 Flysky GT3Cs, all modded to 8ch. Love them, except for one small fault with all of them. The foam of the steering wheel.
Too lose even with new ones and the steering wheel is wider as the foam. The foam always slip and slide on the wheel.
But... I found a perfect and cheap replacement foam! If you have the same problem, here is the solution.
Get yourself a new foam from Traxxas. Part number #2224. It is the foam for most of their transmitters. I tried the foam of my Traxxas TRX-4 transmitter on my Flysky GT3C. Perfect fit. "thumbsup"
The inner diameter of the Traxxas foam is just a bit smaller as the GT3C foam, but perfect for the GT3C wheel. You have to strech the Traxxas foam just a bit over the GT3C wheel and than no more slip.
Bonus, it is just as wide as the GT3C steering wheel, so no more sliding from side to side of the foam over the wheel. And it is also thicker. That last part makes another mod possible. Because now you can use another mod that was only designed for the GT3B.
Because the outer diameter is with this Traxxas foam the same as the outer diameter of the GT3B wheel, you can now 3D print yourself the (OHD) One Hand Drive for FLY Sky FS-GT3B Radio designed by Adam @ Spare Time Hobbies and available at Pinshape.
https://pinshape.com/items/22466-3d-printed-ohd-one-hand-drive-for-fly-sky-fs-gt3b-radio
This OHD mod will not work on the GT3C with the original GT3C foam without changing the design, as in changing the inner diameter of the OHD. But it will work with the thicker Traxxas foam mod without changing anything to the 3D print design.
So there you have it, a mod for a better foam and a way to use your GT3C (and offcourse GT3B) with only one hand.
Yup!!! I've seen the same issue with my GT3C foam. Thanks for the 2224 tip!
