hillbillyHILL
Those of you running the hi-tech 5085 servo what arm are you running?
RPP has the score in stock.
Axial Yeti Jr. SCORE Trophy Truck 1/18th Scale Electric 4WD - RTR
Tower shows late May for both. Lol
I don't know- after reading this thread I think I'll wait till there's either a kit, update to the existing, or a decent deal on a used one where it's already had the elecronics issues addressed.
If anyone cares my bone stock yeti score jr runs 12mph on gps.
My bomber with low gears is faster than that?! Looks like all those motor upgrades are necessary.
With lipo 2s it's actually way faster ..In a fun way not over the top.My bomber with low gears is faster than that?! Looks like all those motor upgrades are necessary.
Haha ya and works awesome ...Now it's fun in the snow with the little guy and amazing run time too.Lmao @full size servo. Heck I would of too. I used a hitec 82mg in my old traxxas mini a long time after the stock one took a poo. Well after the second stock one did anyways.
I replaced the stock junk servo with the hitec HS-85. I didn't have a screw in the right size that was long enough to be able to put the servo saver back on the hitec servo so I just used an aluminum servo arm that I had laying around. Needless to say I clipped my bomber ironically while driving it and broke one of the steering linkage pieces. What size is that screw that hitec uses for their micro servos? I would like to put the servo saver back on so that hopefully this does not happen again. I thought in one of the numerous pages in this thread someone mentioned what size the screw was but I can't seem to find where it was at. Thanks
Sounds good.
Screw is probably 2.6mm if it's same as other Hitec. The new Hitec supposed to all go to 3mm, much better.
Do it!
So i got it full knowing that a lot of people were having issues. Even ordered a new servo which came the same day the Yeti jr came. Charged the battery, and drove it around the living room and it just stopped. Servo was twitching a little bit. Turned it off, and let it sit awhile. Plugged it in again and same thing. Think I got a bad battery or the esc failing already?
