losikid
Got Worms?
I'm having an issue I hope someone can help me with.
Been using 2 hacked GT3B's for a couple years now. SCX10 and a TF2 both using 6 channels with a R6B receivers. I didn't like the big thing on the end of the antennas, so a desoldered them, and have never had a problem with these models. Range is still farther than I can see them, so way overkill for a crawler I'm usually right above.
I'm just finishing up a new rig, using 5 channels on an R6B receiver with one of my GT3B's and got it all programmed up and working great. Went out for a test drive, and I only get about 15' of range, and occasionally less than that. I have an external BEC powering servos, ESC is powering receiver.
First suspect was ESC BEC, so I tried it out using an external receiver pack, no change.
I thought maybe the radio was bad, so I tried it on the model it's been paired with for a 1.5 years and I get tons of range still. R6B receiver.
I concluded that maybe removing that little brass tube on the end of the antenna could have caused this issue. So I resoldered it back on, no change. I then thought that the antenna of the receiver must have broken off the board. Checked continuity with my DMM and everything checked out fine there.
So, I bound an 8 channel receiver to the radio, same exact issue, the brass tube removed from this one too. I then bound a 3 channel receiver I had to the radio, no issues with this one, full range.
I'm not sure what to try next. I know the radio works fine, because it works on an old R6B, and works with a new 3 channel Rx. (I even tore apart the radio to check its antenna connection. Everything is solid).
I can't see how I would have received a defective R6B and R9B from different sellers. I don't think removing the brass tube on the end of the antenna is causing the issue because both my working R6B's have it removed (along with 3 others I've setup for friends), and I've reattached it without a change.
I have also put conformal coating on all the receivers, all in the same batch. Physical examination shows nothing out of the ordinary.
Any thoughts?
I have a new R6B on the way to try that out. Wasn't sure what else I could do.
What happens when you put your old R6B in the new rig?
