Re: Puller Pro Brushless 4 pole Sensored motors- Lays down the Power!
Thinking about running the 2200kv stubby in a wraith on 4s. What do you think?
Should be a fine combo! A little underpowered as compared to running a 540, but not everybody wants to break parts constantly doing standing back flips :ror:
drag break improve , my wraith is about 4.5kg , will the motor stress ?
Motor temp can increase slightly when using lower frequencies, but it is better to have a cooler ESC! The four pole motors aren't loud at 8k, so it is not as annoying as something like an outrunner.
2400 would be sweet... I mean Holmes is the one that thought us to "volt up, gear down"
You all will be happy to know that we shall soon have 2200kv and 5000kv in the 540 size, and 2100kv in the 540XL! About two to three weeks.
The 540XL has such a long stator, that we only have 2100 and 2650kv as good winding choices. There is a speed between those with delta pattern, but the no-load went from 2.1 amps to over 8 amps due to recirculating currents- simply a bad choice. I chose 2100kv as it's low enough that folks could run 6s and get away with it. Also makes it a great 3s and 4s choice without losing too much grunt.
As a fun exercise in theory, I compared the numbers between a 540-S 2200 and 540-XL 2100 as it pertains to torque. The 540XL can produce more torque for any given voltage, based on terminal resistance and difference in KV. About 60% more, using 17.5mOhm and 11.1mOhm measurements for the two. This also means that it will keep a more consistent RPM under a specific load. To be specific, there would be 37% less voltage drop inside the XL. So if the Stubby lost 1000rpm under a specific torque load, the XL would lose only 630rpm. This torque is spread over 2.25 times the stator length (15mm vs 34mm), so we can consider localized waste heat to be 2.25 times less per unit output of torque. Take away message, the XL will handle about twice the torque of a Stubby over long periods without significant RPM loss or heating.
As a less technical comparison, the 540XL weighs 1.75 times a 540 Stubby. Since the difference in weight is almost all active materials like rotor and stator, we could loosely guess it is about twice the motor. A check of the stator lengths confirms, the XL has 2.25 times more active length (15mm vs 34mm). Same take away message without all the fluff, the XL will handle about twice the torque of a Stubby.
