mahgninnuc1
No problem, I also found a pinout from hp, but the walk through on rc tech did a much better job than the pinout from HP.
What power supply? Make & model can help (once you have the info, Google it as well).I just recently got a new PC power supply to mod and it has 12v 18a A and 12v 18a B. Do still tie all the 12v wires together? The wires are 3 yellows and 5 white wires. thanks for any help.
Sounds like you actually have 2 12V 18A circuits in it, I would keep them separate if there are 2 circuits.
after this mod my power supply wont turn on, the green wire is shorted to black, and i have everything but the resistor, could that be my problem?
post a picture of the guts, you don't want to tie the two rails together. Just put 2 sets of posts to hook up multiple chargers
It's not at all as safe as this...Warning:
... anything above 30 milliamps/volts can kill you in a matter of time if it somehow penetrates your skin...
... my power supply wont turn on, ... i have everything but the resistor, could that be my problem?
Not all PSUs need a load to operate, but most older designs do.yes the resistor is what puts a small load on the power supply to simulate it actually being plugged into a mobo
