Tommy R
Here's a question for you.
Where would a semi truck like my old Mean Green 6x6 fit in?
If time permits, I'd like to make another similar to this.
Dean, I think that would certainly fit in Class 2 as it sits in the pic...and maybe even Class 1 with a few tweaks. Here's a few rules for Class 1 that may be of concern:
• Full width bumpers are required on the front and rear of the vehicle. Bumpers that are molded into the body qualify. A rear bumper is not required on a flatbed, but adding one to the flatbed will gain the additional scale points. (Bumpers are measured from the outsides and must be the width of your windshield).
So a full width rear bumper would be needed unless you added a flatbed.
• The tread of the tires cannot extend outside of the wheel wells more then 1/2 of the tread width, flairs can be added to reach min. spec.
This should be easy to address with the right tire/wheel/axle selection.
• Truggies are not allowed, flatbeds with full length rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed. Cab only not allowed.
I think a semi like yours would fit into C1 (I'm considering building one myself!), but technically speaking, it may require a flatbed since "cab only" isn't allowed. Personally, I was planning on playing it safe and put a simple flatbed on the back to avoid any potential hassles.
I hope you build it. Can't wait to see it compete!
