I apologize in advance for this being very long and detailed but its a very specific vision of the future of crawling.
Alot of clubs are running a sportsman class this year, by and large i think that is the greatest thing to happen in crawlers since the invention of dig. Getting new people into the hobby is the ultimate in fun.
Being that crawlers in general have been around for 6+ years now there are many new faces but we also begin to lose some faces. Some people get bored, some people find some other hobby, some just get old and cranky:mrgreen:, lol. Whatever the reason i dont think we should forget that we need to keep people moving with the direction of the hobby and not just focus on new blood. So my idea for this is a cross between a super class (which was originally the premier class) and 2.2 (which %95 of us drive now anyway). I personally feel this could replace the ''super'' class as it allows people to build a more advanced and capable rig with parts they might have now or that are easily available. While this would eliminate the ''super'' as you all know it the spirit and feel of the super class remains in this as there are very few limitations on suspension design. This also has a few goodies to keep it very fun and in the spirit of crawling at the pinnacle of the hobby.
2.2 Pro Class
1) The Vehicle wheelbase is limited to a maximum of 14.5 inches. This is measured from the front axle centerline to the rear axle centerline with all the wheels on the measured side pointing straight. Both sides of the vehicle will be measured at the maximum extension of the axles suspension travel. At no time can the vehicle exceed 14.5 inches in wheelbase throughout the suspension travel.
2) The vehicle track width is limited to a maximum of 14 inches. This is measured from the outermost wheel face with all wheels facing forward at the widest point. At no time can the vehicle track width exceed 14 inches throughout the suspension travel. Toe in or Toe out is allowed provided the outermost face of the wheel-wheel measurement does not exceed 14 inches.
3) The vehicle is limited to 2.2 wheels measured at the bead surface only. Wheels may be modified as needed providing the maximum bead face measurement does not exceed 2.4 inches. Wheels may incorporate any hex size.
4) The vehicle tires size is limited to 7 inches in diameter. Tire diameter is measured at the outermost surface of the tire when mounted on the wheel. If a wheel is in question of being too large it will be measured on the truck with the axle supported in such a way as no weight is being places onto any surface of the tire.
6) Vehicles are allowed to limit any axle or wheel (DIG) as needed. Electronic and/or physical limiters (DIG) are allowed to any axle or wheel.
7) Vehicles are required to have a body. No Bodiless chassis or unibody chassis are allowed. Body must represent a truck, jeep or other ''crawler'' type body, no cars. Any questionable body styles will be at the discretion of the event coordinator or their delegate.
9) Forced articulation is allowed providing it does not alter any other vehicle specs outside of their maximum value as stated above.
10) Independent wheel articulation and motion control are allowed providing it does not alter any other vehicle specs outside of their maximum value as stated above.
11) Vehicles are limited to 4 motors in any configuration the designer chooses provided it does not take the vehicle specs outside of their maximum value as stated above.
12) Vehicles are limited to 4 wheels/tires. The rotation of these wheels are the only form of propulsion allowed. No tracked vehicles are allowed. No walker vehicles are allowed.
13) Automated control is not allowed for any function. All functions of the crawler must be controlled by the drivers transmitter. Gyro's and other forms of ''smart'' suspension are not allowed. Any suspension system in question of being legal will be decided by the event organizer or his delegate.
14) Gates will be a minimum of 16 inches apart measured from the innermost point of the markers used.
2.2 Pro Class
4a) Air inflated tires are permitted providing they dont not exceed the maximum tire diameter in the specified measuring process described above. Remote inflation systems are allowed as long as the maximum pressure available does not force the tire to exceed the maximum diameter at any time. Maximum tire pressure is limited to 45psi for safety reasons.
4b) Any foam or foam system is allowed providing it does not force the tire to exceed the maximum allowable diameter stated above during the measuring process.
5) Vehicles are allowed four wheel steering in any configuration, 4ws, crab, front only, rear only or any combination therein. 4b) Any foam or foam system is allowed providing it does not force the tire to exceed the maximum allowable diameter stated above during the measuring process.
7a) The body must be at least 14inches in overall length, Measured from above from the forward most point to the rear most point along the factory intended cut lines. Folding out the molding scrap to fit the minimum measurement is not allowed.
7b) The body must be at least 6inches in overall width. Measured from above at the widest point in the body. Bodies must retain their full original width at the cab area. Dovetailing is allowed on the front or rear of the body provided it does not narrow the area in question more than 30% of the original width.
7c) The body must be at least 4inches in overall height. Measured with the body sitting on a flat smooth surface from the highest roof line to the resting surface.
8 ) Active suspension is allowed providing it does not alter any other vehicle specs outside of their maximum value as stated above. 7b) The body must be at least 6inches in overall width. Measured from above at the widest point in the body. Bodies must retain their full original width at the cab area. Dovetailing is allowed on the front or rear of the body provided it does not narrow the area in question more than 30% of the original width.
