new2rocks
Cue the opening music:
https://youtu.be/17lkdqoLt44
As you've probably figured out, I got one of these:
Why, you ask? Well...I've never built a GMade kit before (my R1 Frankenstein doesn't count since it uses all Axial running gear), and this seemed a good place to start. Plus, Roo decided he was bored with building CMAXs after assembling his 3rd (true story...he refused to help with the F350 build), and I needed something else to keep him entertained. This seemed like a good excuse to try something different.
The box is rather bossy:
"Assemble kit." Already it's trying to tell me what to do. I don't like taking orders, so I ldelegated:
Roo noticed right off the bat that the axle housings were on a tree:
He wondered why they couldn't mold them without a tree like everyone else seems to do these days. Tough audience.
Tires are fun:
E-clips aren't:
When was the last time you built a kit that had more e-clips than M3 lock nuts? I'm guessing never (unless you just happened to finish a BOM in the past week or so). One of them tried to escape for greener pastures (Roo's words, not mine) by jumping off the table. But we managed.
The tranny has an interesting design. The top section has 3 gears with an open bottom:
There are two other gears with shafts that rest in the skid:
The tranny then rests on the skid, turning these two shafts:
This makes the front and rear driveshafts rotate in the opposite direction, presumably to help eliminate torque twist. Unfortunately, the rear suspension design is very (very) conducive to torque twist, so it will take some tweaking to get things working the way I'd like.
There's one other peculiarity with the tranny. Instead of using a conventional spring to keep pressure on the twin-plate clipper clutch, the BOM uses conical spring washers:
There's another oddity. The instructions call for assembling the two lower output shafts, with loose bearings on the end of each shaft, but not installing them right away:
Instead, the instructions call for assembling (but not installing) the links before installing the tranny and output shafts on the skid. I chose to switch that around, installing the tranny on the skid first and then assembling the links:
Roo did not take kindly to my act of rebellion. There's nothing like getting lectured by your 9 year-old for not following the rules. More updates to come...
Tires are fun:
E-clips aren't:
