crawl-o-matic
www.ottsix.com
![crawl-o-matic-49368-albums2138-58407.png](/forums/proxy.php?image=http%3A%2F%2Fwww.rccrawler.com%2Fforum%2Fmembers%2Fcrawl-o-matic-49368-albums2138-58407.png&hash=1d594c9da1773da60769cb5c8fe63a9e)
FRIDAY 9/11/15
The X4 Race is part of the TrailMaster Challenge
X4 Racing is modeled after KOH
Race format:
-Classes: All TrailMaster classes
-Incremental starts. Depending on the number of drivers, there will be 2-3 min gaps in start times.
-There will be both technical crawling and high speed areas.
-Heat format: Top 50% will advance to the next heat. Number of heats will depend on the number of racers. Odd numbers will be rounded up.
-There will no 'last chance qualifier' type heats.
Rules:
There will be gates. If you or your rig touches a gate, you must pick up your rig and go back to the prior gate. You MUST pick up your rig and physically move it back.
No hand of god. If you're rig flips, you must use a winch or hand held strap to right it. If you touch your rig in any way, ie kicking, grabbing, lifting, nudging, you will be disqualified. This does NOT include accidental touches.
There are NO on course repairs, if you bust, you're done. This may or may not include battery changes, this will depend on the length of the course.
Drivers may not render assistance to other drivers, this will result in a DQ.
-DNS, DNF, and DQ will be listed on the final race report.
Trophies and prizes will be awarded!
