So this will be sort of a build thread for my Wraith 1.9. I've been wanting one of these since it came out and finally had justification to grab one on my birthday.
I wasted no time yanking out the RTR electronics, links and tires. I threw in a HH crawlmaster 13t, Torquemaster ESC and 4.19" tires all of which i had laying around. I did pick up a set of high clearance links from Samix which I sanded extensively to remove their silly markings which i think are laser etched, seriously WTF? I also grabbed a set of Enduro shocks because the provided shocks are the good ole garbage grade Axial shocks.
I also grabbed the BP custom chassis brace with bumper support. Great fit and it really makes a solid mount for the panhard (since its now metal). It should prevent any breakages up front. I do think my rig did get the updated design that adds a little bit more structure to the weak points of the cage.
https://www.amainhobbies.com/bp-custom-wraith-1.9-chassis-brace-w-bumper-support-bpc-wpbm/p980411
The first mod I did was to trim the bottom edge of the body (below the doors). The body hangs below the cage so when you slide up against something its snagging the lexan instead of sliding on the cage. Now it slides on the cage making a less cringe worthy sound and sliding much better lol.
Trimming 5mm or so makes it so the body stops at the mid point of the cage at the bottom.
One area I didn't expect to be an issue was the rear of the body. The body is not mounted at all in the rear and the cage does not protect it from snagging rocks at all.
So I worked up a rear bumper that uses the sway bar mount points. I tried to make it as low profile as possible.
it only protrudes about 2mm past the body
mount points
This is the 1st prototype, I'm just trying to show the body mount points I integrated. I still need to locate exactly where to punch these holes so I can mount the body in the rear.
I need to fine tune the spacing on the body mount tonight but I plan to share the rear bumper on Thingiverse so anyone can print their own if they want.
I tried to lower it by using the (lower) link mount holes but after looking it over the skid just sat too low and the links were angled upwards (from skid to axle) at ride height. Ideally I want them angled the other way or level at least. So I put it back to stock.
I tried some 4.75" tires but this rig is so much better suited to a 4.19" or smaller. The 4.75"ers rubbed so bad on the bumper it was stalling the motor.
One of my favorite parts of this rig is the body and I have no intention of cutting the fenders up for big tires.
Right now i'm running some 4.19" Landmines which hook up very nicely. I also tried out some 4.19" Proline KM3's which worked good too but they definitely had less grip.
![7UoNfo7.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F7UoNfo7.jpg%3F1&hash=e68df006e623ebb2b7db1a129efc2dcf)
![6nf4k2M.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F6nf4k2M.jpg%3F1&hash=fa887807574dc8450e78e6b062ea3b90)
![iYvNyrN.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FiYvNyrN.jpg%3F1&hash=5fb2101077aecaa01fd5f7add2b4eb86)
![lMdDhqK.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FlMdDhqK.jpg%3F1&hash=dd67d1d3b8a91f19af012707cdee4f45)
mount points
![Hg1jfvA.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FHg1jfvA.jpg%3F1&hash=4be2a643e3ff78127ba79c20a812f795)
![NGY0gZ9.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FNGY0gZ9.jpg%3F1&hash=f4188dbaed1e3aa46eaffbdcc2dedadd)
![VWuWt12.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FVWuWt12.jpg%3F1&hash=365ab232d575e5dd9bf9b8c4886bbf05)
