Jury is still out, drive train did not explode yet, but its min speed in low gear is way too fast and it jerks forward from a stand still. I am yet to try changing battery from 3s to 2s to check if it becomes tame enough. In high gear I could not hold full throttle for more than split second, and did not get it to top speed yet. Problem is, even with reduced bump steer, there is enough steering angle change to exceed trucks ability to stay wheels down. At high speeds slight suspension compression can initiate rollover. I should have picked up lower kV motor and different ESC. 2440 did not fit without cutting into electronics tray. 2445 3000kV would take additional 5mm probably resting against servos back.
I dont know if I want to keep experimenting... but if any one has any suggestions on how to slow it down a bit and make it more controllable and low speeds I would really appreciate some know how...
Just for the record, I have bought ESC and motor separately and picked up programmer card at the same time. Those motors are usually bundled with 25A ESC and lower kV are safe only with 2s batteries. My intention was to use it with 3s so beefier ESC seemed a reasonable choice. Programming it to soft start and min neutral range was not enough of improvement.
I know a short video would be helpful to illustrate what am I rambling about. I hope to find some time this weekend.
Water resistance is not exactly top priority yet...
If you really want to have that as a setup, you could go with a lower KV motor and the metal 2-speed gears. It should hold up and be 'crawlable'. What's funny is I planned on throwing in a 7200kv motor in mine.
