WPL C14
Im still rockin the stock servo too, got 6 MG90s servos on the shelf haven't needed them yet.
It's in a good position that it doesn't get damaged by mud or water and it is relatively quick. It honestly works better than my Turnigy TGY metal gear servo. Other than the fact that my TGY has metal gears and more torque. I couldn't find an MG90 single pack on Amazon so I just bought the TG9 servo for $6
Funny you mentioned it, this is what we were doing today early afternoon, and at some point I decided to strap action cam to it with a duct tape...
Ice skating
Finally getting back to my build, but do you know if this ESC has a LiPo Low voltage cut-off?
Your link isn't bringing it up but if its one of those 10 20 or 30 amp esc's I don't think they do I didn't run mine long enough before I switched to the 1625 to find out. I'm gonna put one in another and put a battery monitor on it to see if it does.
Yeah, it's the 30A one.
I'd just put a alarm on it and watch your voltage and see if it shuts down, there's no definitive answer that I've come across anywhere, the switch on it adds a brake but it's not a drag brake.
F/B/R or F/R. Needs a double tap reverse to go backwards.
Okay, so the TG9e is a good deal smaller than the stock servo. I guess i'll just have to use it for my mini drift project instead. What connector should I use? Right now I have XT90's on it because that was all I had. So should I go XT30 or Deans?
Where can I get a set of metal geared axles for cheap but fast shipping? Is that just non existing because these trucks are Chinese?
If you want the stock axles with the metal ring and pinion got to Banggood then type in WPL in search bar then click on U.S. warehouse they should be there, it took mine about 5 days.
I just found a flash deal on banggood. It's the axels without the housings equipped with metal gears. Then the pinions with pumkin cover and half a driveshaft for $9
I am done with Banggood. I have ordered Gaz 66 kit on Jan 28th. Tracking number they gave me ( 5 days later ) to this day shows 'label created'. It is supposed to be mailed from Salt Like City but it did not get there yet. It only had a month... I also placed some orders on Jan 17 and one item is still processing. I understand it takes a long time. Some of us get lucky and get their goods in 2 weeks, some of us dont luck out and wait a month. In my case I wait a month and my merch is still in China. Outrageous.
It’s the Year of the Brown Pig. Started early in February. More than half the Chinese fleaBay vendors are “out” as well.
How do you put up pictures? I have stuff to show but I can't figure out how to get the pics up.
I use imgur. Go to imgur.com register new account, upload your pictures there and then each picture will be assigned direct link. That link you copy into your posts using insert image button. Hard to explain - just ask more specific question when you get stuck in the process.
( Status of my shipments changed, now they are on its way to USPS and within US. no delivery dates yet )
I’d use Tapatalk app and the forum is listed in it. Tapatalk uploads directly to the forum. No copy paste and window flipping. Try that.
