JerryIRacer
What I would like to change yet is to get smaller tires and different offset wheels to have them more within wheel wells and lower suspension a bit for more scale look
I am done with mine. I wanted to try some weathering techniques. It is harder than most tutorials promise it to be. My first attempt was complete failure. For some reason guy in the video was painting dirt streaks with a brush and they looked like like dirt streaks, but when I was doing the same thing it looked like paint brush marks :lol: I decided to wash the body off and start over.
Truck is looking good! I'm going to do something to both of mine for weathering at some point after I get the drive train finished on the C14, I've come up with a way to put bearings on the stock axles that come with the brass ring and pinion still finishing that up so look for that soon.I am done with mine. I wanted to try some weathering techniques. It is harder than most tutorials promise it to be. My first attempt was complete failure. For some reason guy in the video was painting dirt streaks with a brush and they looked like like dirt streaks, but when I was doing the same thing it looked like paint brush marks [emoji38] I decided to wash the body off and start over. Initially I wanted some rust, a bit of dirt and some depth and age. It came out as completely dirty and neglected instead of old and used. I guess I will practice some more on next project - I am thinking about getting one of WPL 6x6s...
Those axles I linked before are available on ebay for $75 a set:
https://www.ebay.com/itm/Metal-Front-Middle-Rear-Bridge-Axle-Kit-For-WPL-B1-B14-B16-B24-C14-C24-B36-RC/233099103705?hash=item3645ca0dd9:rk:39f:0&var
We are getting closer to reasonable price...
CD, good tip on sealing electronics, I just dont know if I want to go that far yet
BTW, those linked above are for a 6x6.
Less than $20usd better? You’ll have to rerun your plastic knuckles and I have no idea about the fitment of swapping the stock bits over.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/113559462157
No, no, and no! Adding weight down low is only positive side effect. 'linked set' has options and set of front and rear axles is $75. Benefit of those over buying just housings and swapping in your own internals is:
1. You do not have to buy metal knuckles and out shafts . Those are included in 'my' set.
2. you do not have to buy metal differential, its already inside. Swapping plastic diff into metal housing is just silly.
3. There are no dog bones. They are replaced with universal joints. It is big deal as dog bones are wear item.
So, it seems a lot of money but it is several upgrades all packaged together and I yet have to sit down and sum it all up to find out where the break even point is.
These WPL rigs have decent to good bodies. The transmissions are lacking, IMO. The upgrade parts that are now available are no better than the Hot Racing clone parts that are/were available for any thing popular.
All that said, putting $75 worth of axles and gears under a $40 kit truck and pushing it with a sub standard tranny is too much for me. Maybe a tranny will come along soon and would justify the money, but currently I don’t see any.
I’ve got a C14 with a 370 planetary driving a transfer case and Losi Mini axles. The speed isn’t much but it has enough torque to crawl a little bit. I’ve driven it for maybe 15 minutes around my garage. Just doesn’t interest me like I thought it would.
I may move the chassis, planetary, and transfer case over to my new c24 whenever I get the leaf springs squared away.
Go to hobby king and look for 850 to 1000 mah 2s with jst plugs if you got that small esc, I'm running a Hobbywing 1625 in mine so I have a 1700 3s also.So what kind of batteries do you guys use? I just got an ESC in the mail today and my truck should get here today as well. The ESC is getting ready to be waterproofed and I might do the servo as well when it gets here. For now I will just use the stock servo, but I have everything to get it running when it's finished being built
You are correct, I also bought two of those to try out, with the two speed though in low gear it will hold itself back pretty decent with 1625.The HW1060 is a little bigger, similar price, and has a drag brake.
As for the metal upgrades/steering mentioned above, it seemed OK after limiting steering angle but on first test drive with the new motor, one of the dog bones somehow managed to jump of its position in the cup and locked itself preventing any steering and movement, had to use pliers to push it back in place, so not much of a recommended upgrade this is..
I found with mine the pins in the dog bones were loose and were flopping around and causing it to bind, I removed them and scored them up and filled the hole with CA glue and they are nice and tight now, I'm waiting on my 2 speed to test them out again.
You're only gonna get a degree or two more out of this setup over stock before it starts binding. My stock setup on my C24 turns great though, I ground the little stops of the stock knuckles and it turns great, the upgraded setup drive cups have too much taper to them, now I hear the drive cups on the set with the brass gears have less taper and work much better, the set I got has the black steel gears.Do you know how to get more steering angle out of these?
