wmax99 wraith projet
wmax99
repentigny qc
ok i started whit a wraith kit and i want to order those upgrade for now
not recived everything but its my winter projet ;-) so anof time for get all the cash for mod let me know what im missing or change its my 1st wraith so want to make it great
esc mamba max pro
motor tekin pro4
14t pignon robbison
56t spur robbison
beefy top shaft
hr steel center gear set
hr alu Suspension Rod Steering Link Diff Cover Set
mip Splined Center Drive Shaft Kit
2x hr alu lower shock mount
hr alu front upper link servo mount
hr alu rear upper link servo mount
hr alu servo mount
hr alu front steering knuckle hub
hr alu c hub caster block
fast eddy beering kit
RTR Stainless Steel cap screw quality kit
servo savox sc1256tg
so what u guys think of this set up ;-) i cant wait for some feedback so i could start ordering my stuff well combo is ordered and alredy have the servo so just need ur help for the rest :) thx
max
Axial HD gear set for the axles as well the pro 4 wont be nice to them lol. also id go ahead and get a different diff cover because that HR one is really thin and ive seen about 3 covers totally smashed in. Make sure you order 32 pitch gears as well.one last thing is a HR uni-body locker for the sxle shafts. other than that looks good, im slowly getting parts rolling in every 2 weeks for a winter project, im doing a 4ws wraith kit with all the vanquish goodies and holmes hobbies motor/esc.
ok il add that ;) and the rear titanium from cbrb fab whit diff cover u sugest ?
thx
Vanquish products diff covers are nice, 25$ a pop but well worth it, i got one thing from VP and was so in love with the work ill only buy their stuff. yeahthose are nice too, im doing 4ws so im running dual VP VVD drive shafts
do u have the link for the vvd drive shaft i dont see them and i was looking at then the vp hd axle look great whit the red end and i was wondering for the diff gear f/r are they solide anof or we need to remplace it
k me i dont need 4ws il do more trails and sand pit the crawling so ;) but maybe in futur im thinking to build 2transmision 1 for speed run whit the pro4 and 1 for crawling whit a 35t motor and stock setting
Lol most of this post I don't understand :lmao:
I'll try n help with what I can, vanquishproducts.com is where you will find the wraith axles, in the wraith section along with the diff covers. Second part about the diff gears I don't understand. Rc4wd has a 2 speed tranny you might wanna check out for the wraith, idk if it will hold up with a pro 4 though. Come back again about the diff gears and I'll help "thumbsup"
sry im french so might not be clear ;)
i mean the gear in the front and rear diff are they solide anof ( cos the look kinda cheap) or some1 make some ? and i was meaning to have 2 tranny set up ( have 2 full transmision whit different moteur ) have 1 for do some speed trails whit the tekin pro4 and 1 whit a 35t motor more for do some mud /crawling
cos lots of ppl are saying that the pro4 cant go in water/mod so il get 2set up il just have to change the transmision for what ever i want to do whit the truck
If you get the axial HD wraith gears you should be fine, Nobody makes any aftermarket gears for the trams that I know of. Oh okay I understand, yeah that would be cool but if you waterproof your esc and motor you should be fine for water and mud. But if you don't want to water proof it then it would be cool to have the tranny deals where you just swap them out. Or go the extra mile and have two wraiths :mrgreen: that's what I'm doing, I'll have two wraiths, one for comping and such, the other for bashing and playing ;-)
Oh and i hope I didn't offend you with the not being able to read your post remark, I didn't realize you were from another country haha
not at all im still learning englich so i understand that ppl dont get my point cos most of time im kinda gessing what i wrothe ;-)
there some pic of my body home made ;)
looks good man. if you want the lines on the hood to be more of a "crease" or straight line, try putting them on the corner on the counter or workbeench or whatever and hit them with a heat gun for a few seconds at a time while lightly pushing twords the corner
