cossack
is it possable to wire a omg hdt045070b direct to a battery instead of using a bec as it is listed on there site that it can take 7.4v
Specifications
High Voltage Low Profile 7kg Brushless Digital servo
Item No.: HDT045070B
Modulation: Digital
Weight: 45g (1.59oz)
Dimensions: 40.2 x 20.1 x 25.2 mm (1.58 x 0.79 x 0.99 in)
Gear Type: Titanium
Motor Type: Brushless
Rotation: Dual Bearings
Stall Torque: @6.0V: 5.5 kg-cm (79 oz-in) @7.4V: 7 kg-cm (97 oz-in)
Speed: @6.0V: 0.06sec/60° @ 7.4V: 0.05sec/60°
i know peolpe who have done this with a hitec 7950th and had no problems
Detailed Specifications
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-7.4 Volts
Operating Temperature Range: -20 to +60 Degree C (-4F to +140F)
perating Speed (4.8V): 0.18 sec/60° at no load
Operating Speed (6.0V): 0.15 sec/60° at no load
Operating Speed (7.4V): 0.13 sec/60° at no load
Stall Torque (4.8V): 344oz/in. (22kg.cm)
Stall Torque (6.0V): 402oz/in. (29kg.cm)
Stall Torque (7.4V): 486oz/in. (35kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
Continuous Rotation Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 9mA at stop
Idle Current Drain (6.0V): 9mA at stop
Current Drain (4.8V): 220mA/idle and 3.8 amps at lock/stall
Current Drain (6.0V): 300mA/idle and 4.8 amps at lock/stall
Dead Band Width: 1usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: Titanium Gears
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.57" x 0.79"x 1.50" (40 x 20 x 38mm)
Weight: 2.40oz (68g)
i just wanted to know if what i want to do is safe
cheers
Specifications
Modulation: Digital
Gear Type: Titanium
cheers
