fyrstormer
This is something I've been wondering for years, but I only recently decided to actually write it down. Hear me out, I haven't lost my mind.
Shafty rock crawlers typically have fully-locked drivetrains, oftentimes with a higher gear ratio in the front axle for better climbing and cornering. Additionally, shafty rock crawlers are sometimes equipped with a "dig" gearbox that allows the rear axle to be locked like a parking brake for extremely sharp turns or completely disengaged so it can freewheel.
Despite the use of overdrive gears in the front axle and/or the use of a "dig" gearbox, it is quite common for a shafty rock crawler to jam its front wheels against the front face of an obstacle while the rear wheels continue to push the vehicle forward into the obstacle. Very careful use of the dig function can minimize this problem by allowing the rear wheels to be locked, so they act as a fulcrum while the front wheels start to climb the front face of the obstacle. However, as the front of the vehicle lifts up, the locked rear wheels roll backwards slightly; as soon as the front of the vehicle lifts up enough to relieve the pressure on the chassis, the front wheels will start to lose grip, potentially causing the vehicle to slip and lose progress.
Additionally, when climbing over the apex of an obstacle, it is quite common for a shafty rock crawler to exhibit significant torque-twist with one front wheel lifted into the air, because both rear wheels and one front wheel have significant traction, preventing driveline torque from being relieved. Typically this is dealt with by steering the wheels side-to-side, allowing them to slip slightly until the driveline torque is relieved and the front wheels settle-down onto the ground again.
Overdrive gears are useful for improving cornering (wherein the front wheels need to rotate faster than the rear wheels), for sometimes reducing torque-twist when apexing an obstacle, and for reducing the "jamming" scenario I described two paragraphs above, but overdrive gears are an incomplete solution. They also cause driveline torque to build-up constantly when a shafty rock crawler is driving in a straight line, causing the chassis to lean to the side, which can cause the vehicle to tip-over when side-hilling. Furthermore, as the existence of "dig" gearboxes shows, there are many scenarios wherein it's necessary for the front wheels to rotate so much faster than the rear wheels that no reasonable overdrive gears could provide the necessary difference in wheel speed without causing unacceptable torque-twist. "Dig" gearboxes themselves are an incomplete solution, as they require split-second manual operation for best results, and they inflict an immense load on the motor, causing dangerous heat buildup in a matter of seconds as the motor is forced to drag the vehicle forward against the drag of the locked rear wheels.
It seems to me that these problems could be significantly reduced if shafty rock crawlers were equipped with center diffs. If a center diff were filled with 500,000-1,000,000wt silicone oil, it would split torque almost 50:50 between the front and rear axles even at very low speeds, while also allowing just enough freedom of movement for excess driveline torque to be relieved, and for the front wheels to rotate significantly faster (albeit only at very low vehicle speeds) when cornering sharply or climbing the front face of an obstacle. In particular, when climbing the front face of an obstacle, the rear wheels would still be able to exert forward force on the chassis, keeping the front wheels pressed against the face of the obstacle, while simultaneously allowing the front wheels to rotate much faster than the rear wheels to actually climb the obstacle.
With a center diff, it may be a concern that the rear axle could spin freely while the front wheels are stuck, such as if a front wheel gets jammed in a hole. However, that could be remedied quite simply by equipping the center diff with a one-way bearing that allows the front axle to rotate faster than the rear axle, but not vice-versa. Alternately, the center diff could be equipped with a locking mechanism similar to the diff-lock mechanisms used in the Traxxas Summit and TRX-4/TRX-6, though the one-way bearing solution would eliminate the need for an extra servo and radio channel, thus being less expensive to implement.
Thoughts?
Thoughts?
