Wheel Pics - No talking
Mayhem Madness!!! 1.9 Monsters...
It took me about an hour to mount the PL Flat Irons - can't wait to get'em dirty!
My wheels:
Vanquish SLW V1 1.0" in grey with a stroke of Faspearl Blue on each spoke.
Raw aluminium beadlock rings.
HB Rover tires, ventilated through three small holes punched on the inside of each tire.
Fake brake disks by Tomy.
.850 Losi hubs on the front, .600 Losi hubs on the rear.
Picked up two new sets of truck shoes.
CAC 2.0 BAMF with 1.9 RC4WD Prowler tires, Rogue Element hubs, and Integy brake discs.
RC4WD 1.9 Pro10 Steelies with 1.5 RC4WD Mud Thrashers stretched on there. These are for my little baja truck.
Here's the latest edition to my addiction!
VP awesomeness!!! Now if only I could decide what tires to mount up on them...
start with a set of box stock axial rocksters.
now these are cheap as sin and ok for a beginner beadlock, the easy strip hardware provided leaves much to be desired to say the least, but i have a solution.
chuck them up with a stub axle and 12mm hex in the drill press and get to cutting. i have a cross-slide vise, but i'm too cheap to buy actual cutting bits, so i just used a mini screwdriver in the vise. if all goes according to plan (not all on fire and melty) then you'll end up with these.
so cut some 3/4" spacers out now. i have about 15 ft of 1/4" delrin tube sitting around, and a couple hundred 4-40 bolts as well. so i drilled out the face sections and rings, then threaded the tube to 4-40, and bam. spreader style wheels on the cheap. weight in at 1.5oz each, and i can tighten the rings down solid now.
the 3/4" spreaders make for a wheel just a hair over 1 inch wide.
Cut and Shut Swampers
Grip Fab 2.2 Hoopty Pros wheels
Rogue Elements Knock Off's
RC4WD Scale Hardware (not finished yet, gonna switch to Locked Up hardware)
