What servos do you use for your 2 speed and dig?
pchiumiento
Mass
I bought another micro spektrum servo SX108 to be exact to put on my 2 speed in my Early Bronco. Even with the servo saver that it comes with to use it seems to have worn itself out a little or doesn’t seem to really have enough power to shift gears anymore. If I set the end points a little past where it should go it can work a little better but it still doesn’t always shift gears.
I am looking for a micro servo that will work for this with plenty of power no issues but that doesn’t cost to much. Any recommendations are appreciated thanks.
I haven't had a chance to use this servo on my SCX 10.3 yet but I do use it on my Ryft for shifting the 2 speed now for about a year or so with no issues or complaints.
They cost about 15 bucks and can run high voltage as well and fit the stock axial servo shift horn perfectly.
Eco Power 827
Couple pics of the box with specs
Sent from my SM-S908U using Tapatalk
Eco Power 827
Ok, thank you I will check those out. Can’t hurt to buy one and try it.
How did this servo work out for you?
I've been using the 108 Spektrum model servo for dig lately with no problems or complaints so far. I didn't like the adjustability of the stock radio so swapped out to a GT5 which allowed me to set the end points better. Works flawlessly now "thumbsup"
I've got the agfrc B13DLM V2 for the 2spd on my bomber, and dig on my scx10 pro. No trouble in either rig.
In my Phoenix, I picked up a pair of the Injora 7kg micro servos to shift the vfd twin. The main selling point on the Injora servos was they use a standard 25t horn and handle 8.4v. I've had no trouble with these either.
Good info....thanks. I need to replace the dig servo in my Gladiator and I'm contemplating hooking up the 2 speed also?? :)
Been using the Reefs 99Micro for most of my mini servo duties. Have to get a 25T micro horn so I juts buy the Reefs horns for them and mod if needed.
