What Powers Your Wraith?
what do you internet people think of the following?
cc sv3 esc
4600kv brushless cc 4pole
RR trans
mip axles
2s 4000mah
savox 1257tg
novak BEC
80/21
Update on mine :
MMP
Cc 10 amp bec
Trinity revtech sensored brush less 13.5(4000ish kV)
84/18 48 p
Hi-tec sh-7954hs
3s 4000mah 11.1v
My sons:
Stock ae-2
Cc 10 amp bec
Integy 35t
87/17 48 p
Hi-tec sh-7954hs
3s 4000mah 11.1v
I'm a little bit late to this party but,
Novak Timbuk2 Wraith edition esc and brushless motor
Stock pinion (I think I could go to a higher tooth count easily)
5000mah 2s battery
I dunno how it compares to other out there, it doesn't have a ton of top speed but it is smooth as butter on the rocks. I've had it about 2 years now with no issues at all.
5000mah 2s battery
Me too, the only issue I have is the drag brake can't be turned down too much before the ESC starts to do weird things.
A very nice set up
Lots of power and good speed
Tekin RX8
Tekin ROC 412 3100
5000 2s 40c this system can operate on 3s but it is just way too much, there is no need for it.
Airtronics mx3x
Check it out under So Cal Wraith
HH BRXL
HH TorqueMaster Pro 27t
Savox SA1283SG
CC 10a BEC
Gens Ace 3000mah 25-50c 3s
Sanwa MT-4 & RX-371wp
Castle Mmp
Tekin redline 18.5
Castle 10 amp bec at 7.4v for steering and led roof lights
Hitec 7955TG steer
Maxamps 6500 3s true 150c under hood
Rc4wd 2 speed trans with micro hitec for shifting
Mip driveshafts
Full Vanquish axles setup
Futaba 4pl radio gear
Integy switching control for roof lights
Hobbywing Xerun 3656sd 3400kv
Hobbyking X-car 120A v2.1 Esc
Gens Ace 2200mah 55c 3s LiPo
SuperShafty motor plate
Hot Racing hardened tranny gears
12/56 32p gearing
Hot Racing steel lockers with hardened gears
MIP driveshafts
Makes the wraIth an excellent bouncer with great low speed control.
I just like to know from the 'CRAWLER/TRUCK' GURUS among us if I'm correct in my assumptions about having to change this power system to keep from destroying my newest acquisition?.........
I've recently optained (but have yet to take physical possession of) a pre-owned Axial Wraith that's been outfitted with all sorts of 'BLING'.
I don't believe that the previous owner had ever run it, or if he did, it wasn't run for very long.
My understand is that it was 'custom' built for someone else who never took possession it, and it's basically been a 'SHELF QUEEN' ever since.
Now here's my concern; It's got a CC Mamba Max ESC & 4600KV BL motor running with a 3SLiPo.
That seems like a lot of motor (high Kv) for this application.
Now, from what I understand, this particular set-up isn't compatible with this type of vehicle, and the use of such a power set-up would not only perform poorly, but would also damage the drive components as well.
That's not a very happy scenario.
So, I'm figuring that I'll need to replace this existing ESC and motor combo with a system that's more compatible for this application before operating this rig.
Even though I've been flying EP RC aircraft for almost 10 years, this ground-pounder thing is new to me.
http://s72.photobucket.com/user/MaxHeadspeed/media/RC%20Ground%20vehicles/AxialWraith_zpsa5056d15.jpg.html?filters[user]=139297740&filters[recent]=1&sort=1&o=8
