What is Torque Twist
The differential:
So there are two gears inside the differential (AKA pumpkin). They look like this, the ring gear is the big one that looks like a ring :ror: and the pinion is the little one. The shaft that sticks out of your differential is the shaft of the pinion gear. The driveshaft bolts to the pinion gear and spins it, forcing the ring gear to turn. The ring gear is attached to your locker/spool which drives the axles.
The history:
Remember how things in motion remain in motion unless acted on by another force? (in space shit keeps going forever, on Earth we have to battle air resistance and gravity). Well the opposite is true to, if things are not moving they don't want to start moving. This resistance to changes in motion is called inertia. The fridge doesn't want to start moving! :lmao:
More history:
Imagine you are the fridge, and this dude is laying on top of you. Not only do you have to overcome his inertia to get his drunk ass off of you, but gravity is pushing him down. You have to work extra hard to get him off. Just in the same way the weight of the whole rig has resistance to move. This resistance is increased when climbing up steep inclines or when the rear end is bound up. The more resistance to movement is present the more torque twist will rear it's head.
What happens:
When the motor starts to spin and applies a force to the driveshaft/pinion, the inertia in the wheels/tires makes the ring gear not want to move. Just like pushing into a fridge, the transmission is like a little kid trying to spin a giant nut driver attached to the top of a fridge. Only your chassis isn't standing on the ground so we have to change the analogy a little bit: the kid is suspended in the air by a bunch of spings and dampners. :lmao::lmao: When he tries to spin the driver, he himself will just rotate.
Another factor:
The motor itself plays a small roll. The part that spins inside the motor has mass and accelerates very quickly. When it suddenly speeds up or slows down it wants to rotate the case. The case is mounted to the chassis. When the motor changes speed quickly it will try and rotate the chassis.
How to stop torque twist?
Weight distribution
EeePee had a great idea to mirror the transmission, so the weight of the motor hangs off of the right side of the chassis. This makes it harder for torque twist to lift the right side of the chassis.
Dealing with the resistance to movement
Springs and Shocks
Picture the kid suspended in the air again, if we used stronger bungees and beefier dampeners he would rotate less as he tried to spin that giant driver. This would be akin to beefier springs, thicker oil, and a shock angle more inline with the path of the axle. You can also use a smaller hole or fewer holes in the shock piston. Softer springs up front will let the chassis flex more during TT and will help keep your right front tire down.
Antisquat
You can set your links up for more antisquat to keep the rear from compressing on acceleration. If you need help with antisquat, see this thread: http://www.rccrawler.com/forum/general-crawlers/362032-diagram-anti-squat.html Some people like to run different antisquat values on either side of the truck (left to right) to help combat the twisting of the chassis.
Weight
You can weight down the front axle, or the front right wheel. Knuckle weights or weights far out, away from the diff, will make it harder for the chassis to pick up a tire.
Diff Gearing
A higher ratio ring/pinion combo will make more torque and the driveshaft will use less force to make the wheels spin/rig move. Underdrive gears all around will make the biggest reduction. You can also combine underdrive rear and overdrive front which will help reduce TT when going forward by stretching the rig out. The overdrive in the front will make the front tires spin faster than the rear (I have read it's 9 front tire revolutions to every 8 rear). This stretching will compress the suspension a little bit.
If I need to add anything else, or if my explanations are not up to snuff, let me know and I'll make things more clear and complete.
The differential:
The history:
More history:
What happens:
Another factor:
Weight distribution
Springs and Shocks
Antisquat
Weight
Diff Gearing
