Ok, so I brought home a 10.2 SCX builders kit earlier and some Pro-Line Hyrax tires on some wheels.
at this moment I am planning on doing a pro-line gladiator body, but not 100% sure due to it being a lot smaller in scale size than most other 1/10 scale bodies. Only reason I want to do it, is because i drive a 1:1 gladiator and want to try to mimic what I drive.
For electronics, that is where I need a little help and guidance. I am trying to do a budget friendly build if at all possible. Here is what I am thinking so far:
Hobbywing 1080 for ESC.
Flysky GT5 with Flysky receiver many of them come with online.
holmes hobbies crawlmaster or trail master motor.
no clue on battery, thinking 3S
Here is where I need help.
For the motor, can a 550 fit on the SCX10.2 chassis? Why would a 550 be more beneficial over a 540, or is it? What works well with turn size? I get a little lost here when it comes to the sizes and gears.
For the battery, it looks like the HW 1080 has a XT60 connector. Do I need to find a battery with this style of connector or do I just change the plug out to whatever I end up with?
What about battery size? I want to run 3S just for a little more umph when I dont feel like always crawling. what MAH is a good one for playing a good while? WHat about the C rating?
The scx10.2 build kit looks like the battery is a little on one side and forward biased, is there a certain body size of battery that works best for these 10.2 kits?
What is a good cheap charger that will work well for the battery choice?
Any help would be appreciated. Ill probably start bolting things together tonight on the chassis build.
