allanon1965
Alright, we moved into our freshly built new home Christmas eve 2017. There were issues right away with the water and other things we wont go into detail on those other issues...suffice it to say the wife picked out the home and hates everything about it now.
the water test done at the site while building showed 129 micro grams per liter... at the time I am looking at that and saying WTF?!?! PPM is the standard measurement as far as I know and is used by all the water companies/well drillers here.. it seems to convert to .129 PPM.
the water had a yellow/tan tint to it and a slight eggy smell. I had the water tested by a water conditioning company, eco-water systems and it came back with 4.5 PPM of iron. The iron in the water was reportedly clear water iron, as it had not oxidized in the well or lines and turned rusty in the toilets after some time in them.
I had a water softener that claimed it could get rid of up to 10 PPM of iron. I found out later that didn't include clear water iron. I tried an additional air injection iron filter system that almost worked, but not quite. I finally went with the Eco Water company and their softener/iron filter system.
Initially there were issues with their system as well but it came down to the time for regeneration was 12 midnight, not 2 am as I was told and the wife was using the water a few times when the system was regenerating, unbeknownst to us at the time.
When I discovered the issue, I fixed it myself by adjusting the time it regenerated to 2 am. 2 days later we have yellow tinted water again! WTF!!!! I call the water company and they come out to test 2 days later and the water is clear by that time and no iron found. This goes on for a few days and I soon see there is a pattern to the discoloration.
The water discolors a day or so after we get rain. I call the well company to come out and check the well to make sure there is no issue with rain water infiltrating the well. They find no issues and again, after a rain the discoloration comes back. I decide I am going to install a whole house filter before the water hits the water softener/iron filter.
I install a filter from Omni Filter and put in a 5 micron poly string filter. The water seems clear enough but it wasn't discolored before I hooked up the filter. The next day we get rain...the day of the rain, no tinted water..the next morning however..its back! This crap must be related to Arnold cause it keeps coming back!
Now I am pi**ed off! I look at the filter and its not very dirty but it does have some rust in it so I figure I will trade it out for the 25 micron carbon filter that came with the housing(i was thinking 25 microns was too big and wouldn't filter out the yellow tint) and low and behold after 5 minutes of flushing the water is freakin clear!
the pic below is the yellow water in the left sink from this morning (its darker than the pic shows) and the water in the right sink is the clear water after installing the 25 micron carbon filter. The housing is clear so I can see the filter media and it got discolored real fast but I think it will last for awhile, its rated for 50,000 gallons or 9 months. Hell even if I had to change it once a month at 20 bucks a filter that's a bargain!
Kudos if you stayed with me this long and got thru reading the horribly written rant!
