Hey all I haven't been active in a bit, but this is my most visited RC forum which seems to have some very well versed members.
First of all, this is on a Gasoline powered 1/5 scale vehicle.
The electronics: FlySky FS-ITS4 Transmitter with its respective 4 channel receiver, SVT module and the respective failsafe module. running on a 5000mah 6.0v battery pack. 2 Hitec HV Metal Gear Steering servos and a Hitec HV Metal Gear Throttle servo.
The weirdness.
This transmitter combo works great for 9 of the 10 models I have programmed in it.
It previously worked fine on this model also as recent as yesterday.
Today it started doing something very weird. Whenever I crank the engine on the vehicle, the transmitter reboots.
So long as I do not crank the engine the transmitter and receiver stay bound normally and all the functions work and response is normal.
The moment I yank the pull start the transmitter will reboot.
I have tried tapping, hitting, smacking all around the transmitter box, pull start housing, pulling on any exposed wires, hitting the emergency shutoff switch, and even dropping the vehicle to try to recreate the reboot to no avail.
It will only reboot the moment I pull that cord and the engine cranks over.
I'm truly stumped on this one
The weirdness.
