Jay-Em
I shortened the shock’s throw by about 1,5 to 1,8cm by way of inserting very stiff short springs ùnder the piston. Had some left from a desert lizard set, and they fit quite nicely in the alu bodies of the Bronco’s shocks. It fixed a lot of the torque twist, while leaving some leeway when extending/over extending.
Stock the Bronco rode way too high for my taste. Hence the shortening. That it also partially fixed the twist, was a bonus.
Edit: And, Yes, a heavy 5000mah pack in the rear makes it twist worse than when you use, say, a small 2200mah on the little shelf in the middle of the chassis.
