Krawlin
Please post all of your VW Bug body paint schemes. I just got a new one, and I need some ideas. So please, any VW bug body will be great. Thanks.
-Chris
-Chris
If anyone has some info on marbeling techniques with saran wrap, please post them. Thanks again. -Chris
The marble look is easy. I usually use a plastic bag instead of saran wrap, only because I can always find one. I'll pick the two colors that I want to use and for me at least I always use the lighter color first. I pour a little paint on something and dab the bag into the paint. I always blot the bag a few times to make sure that the first time I put it on the body it does not come out too thick. Cover area wanted, then fill in secondary color.
Alright, I dont think I fully understand your directions, but I have another question...
If I just spray the base coat (Chevy Orange), can I take a piece of a plastic bag or saran wrap, and lay it on the paint, and then take it off, leaving me with a marbeling effect?
Or do I need to spray, then lay/dab plastic on the paint, then take the plastic off, and spray black behind the orange, then do I get a marbeling effect?
The second one is right. Spray, dab, let dry, then back. If you did the first, all you'd have is the orange with clear spots with the lexan showing through!
Depending on the colours used, you can do a three step marbeling effect. If you use a metallic or candy that is semi-transparent, spray that on first in a light coat, let dry, back with silver, blot this, let dry, back with white or black.
The following picture isn't mine (off of the CFX forums), but shows the results:
Note also this was done by a pro, but it's still a relatively simple effect to create!
Chris
Edit: Practice on scrap lexan first! No point trashing a $30 body by screwing up the paint job.
