I got a good window for paint this afternoon. But first I'll share a tip that I've found extremely helpful for setting window masks or stickers.
First step is to cut the backing the same outline as the mask or more. Cutting it exact is pretty hard and may mess up the mask. I found you can cut just inside of the outline of the mask, peel the mask up enough to get the tip of the scissors under it but dont cut too far because you dont want it to stick too much yet. then you cut off a small section of the mask on one side, this will be used to stick the mask down as you align it.
like so
Then you stick it on and start adjusting until its nice and straight. I like to look at it from the outside to double check placement. Since there's only a small amount of the underside of the mask that will stick pulling it back up to re-adjust is easy.
Once that's aligned pull the edge up that isn't stuck down so you can remove the rest of the backing and stick the rest down.
No more sticking the whole thing down only to have to attempt to pull it back off then have it curl up on you. This method makes things so much simpler.
I went with 2 light coats of Tamiya red PS-34 backed with black to darken it up a bit. I was actually hoping to be a bit more inconsistent with the red coats so I could get some variation but its pretty minimal. You can see the variation a bit if you look for it.
This is the first rig I've really stickered up. I'm not a big sticker guy but I thought it would fit with this build. Lucky for me I still save stickers and had a massive pile to pull from.
I found a sticker for all the brands that make up this Mutt build. Actually I think I've got stickers for almost everything but Hobbywing and Spectrum (their stickers kind of suck)
I dont think I'll keep this but I'm playing around with a way to not lose the front body pins. This is something I do for every rig as a rule. Either magnets or some spot to clip them in place.
I also cut the rear of the chassis rails back to the shock towers, it was maybe 1 1/4" - 1 1/2".
I think its pretty much done surprisingly, but I'm stoked. I didn't want this one to be drawn out too long even though I really enjoy the build part of it.
