Smokin' Joe
I previously modified my Everest 10's skid plate for better link geometry and to countersink the screws. See thread: http://www.rccrawler.com/forum/redcat-rs10/570358-my-e10-skid-plate-mods.html
Since then, I've bought a couple more Everest 10s for my sons, but hadn't taken the time to modify their skid plates. I saw that the Vader products skid plate for the Gen 7 did the same things my skid plate mods did and bought a couple for my sons' rigs.
In order to install the Vader skid plate you need countersunk M3 screws for the tranny. I used 4 M3 by 12mm screws, but you could probably use up to 14mm screws. You also need different balls for the rod ends where they connect to the skid as the redcat ones are too large for the space in the skid. I used traxxas ones which fit perfectly.
The other issue with installing this skid on the Everest 10 is that the Vader skid is quite a bit thicker than the stock skid. This raises up the transmission and causes it to hit the underside of the battery tray. I used my dremel to grind the underside of the battery tray in order to make everything fit.
Pics to follow.
Pics to follow.
