@bmow , no worries, this build got set aside for a bit was just accumulating parts.
Build pretty much finished. Currently stock shocks/towers but that may change, haven't even driven this rig and their leaking.... also thinking of putting OD gears in the front.
Moving the rear shock towers to the forward holes gave ot a bit more flex for sure.
Treal diff covers and steering link will be here today. Injora cover will go in the rear of the defender. Don't like the flat faced diff covers.
Bumpers including mount brackets, sliders and roll cage all my design, interior is off thingiverse.
Got the injora brass hubs, diff covers. Going to do testing to see if I want brass or aluminum Cs for it.
Injora high clearance links
Full NSDRC Steering servo set up
Furitek Lizard pro with BT on a Mofo 1900kv motor, stock gearing.
Designed and printed a new battery tray, bit lower and fits packs that are a tad bigger than stock.
Esc takes a little tuning but is AWESOME. Low speed torque is there, was a bit too much at first as it had torque twist from hell. Got that sorted. Low speed control is crazy. Thing will creep for sure.
Also finally completed the first indoor course section. So was able to test is out a bit.
Sent from my SM-S906U using Tapatalk
